internal battery replacement
2010-11-13 by max
Index last updated: 2026-03-30 17:24 UTC
2010-11-13 by max
2010-11-13 by Summa
On 13 Nov 2010 at 16:54, max wrote:
> i am so sorry for such an obvious newbie question but i've been
> searching the archives and searching with google, and i just
> wondered is there anywhere a step by step guide to changing the
> internal battery?? I can't even work out how to open the case!
> any help very gratefully received,
> thx,
> max
> Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
> http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
CZ/VZ mailing list : http://groups.yahoo.com/group/CZsynth
FMHeaven mailing list : http://groups.yahoo.com/group/fmheaven/
FS1R mailing list : http://groups.yahoo.com/group/fs1r/
Vokator mailing list : http://groups.yahoo.com/group/vokator
FM-Synthesis mailing list : http://groups.yahoo.com/group/fm-
synthesis/
http://www.summasounds.de/
2010-11-14 by ubergvx
> Just open up the bottom of the synth,>Yeah, opening the case is simply a matter of removing the screws on the bottom - lots of them! No need to keep track of which goes where; they're all the same. When you flip it over, rest the top on something that won't damage the knobs (I use a couple of stragetically placed paperback books). The battery is the silver disc, about the size of a quarter; pops right out of the battery holder. Go buy one with the same number, pop it in. They're most commonly used as "security system" batteries these days, so hardware stores usually have them.
2010-11-14 by Jeff
> BTW, you can remove/replace the battery without losing patches inRight, but beware of short circuits !
> memory, by leaving the power supply plugged in and the power on while
> doing the battery swap. I'm sure this isn't "recommended" but I tried
> it once and it does work. There's only 15 volts in there...
> --- In AN1x-list@yahoogroups.com <mailto:AN1x-list%40yahoogroups.com>,
> it once and it does work. There's only 15 volts in there... If you
> don't wanna to this, have some way to save & restore your patches.
> AN1xEdit is great; look for discussion of AN1xEdit on this group.
> Van
2010-11-14 by boogie_koski
>And If,.. Your new battery don't go into it's place, just go and exchange/buy new one from different manufacturer. Usually they match, but not 100%. I bought first Renata CR2450N (is that N the difference?) and no way to put that into the holder!
> Just open up the bottom of the synth, it's mostly CR2450 and not the
2011-03-11 by Jerome St-Pierre
> Varta CR2450 just cliked in.
> Greetz, Boogie.
J�r�me St-Pierre
2011-03-12 by Jerome St-Pierre
> Hi all,--
> I will soon change my battery and I am wondering if I should backup my
> patches before proceeding? I guess not by reading this conversation but I
> would just like to be sure...
> Thanks,
> J�r�me
>> Greetz, Boogie.
> J�r�me St-Pierre
> Never mind. I searched some more and other users said we must make a backup--
> before changing the battery.
> But I still have another stupid question. I don't understand how removing
> the battery could affect the patches? Aren't they saved on some kind of hard
> drive? Or are they really kept loaded in memory with the battery?
> I have no clue since I never did anything like that...
> Thanks for your help!
> On Fri, Mar 11, 2011 at 9:41 PM, Jerome St-Pierre <
> jeromestpierre@...> wrote:
>> Hi all,
>> Thanks,
>> J�r�me
>>> Greetz, Boogie.
>> J�r�me St-Pierre
> J�r�me St-Pierre
2011-03-12 by Peter Korsten
> But I still have another stupid question. I don't understand how removingA hard drive? We're talking about a few kilobytes, at most, of data.
> hard
> Even in 1997, when the AN1x first came out, a hard disc would have a
> capacity of several gigabytes, which is in a totally different league.
> (1 kilobyte: 1024 bytes; 1 megabyte: 1024 kilobytes; 1 gigabyte: 1024
> megabytes.)
> So yes, it's just a little bit of memory backed up by a battery. Today,
> I saw the 'low battery' warning for the first time. Have had the AN1x
> since 1998...
> - Peter
J�r�me St-Pierre
2011-03-12 by Jeff
> Never mind. I searched some more and other users said we must make a backupYES, unless you don't mind to loose all the patches stored in your
> But I still have another stupid question. I don't understand how removingYES. These patches are stored in a static CMOS RAM (not a flash
> I have no clue since I never did anything like that...If you don't want for some reason of your own to make a memory backup on
> <jeromestpierre@...>wrote:
>> Hi all,
>> Thanks,
>> Jérôme
>>> Greetz, Boogie.
>> Jérôme St-Pierre
2011-03-12 by Jeff
>> backup
> keyboard (i.e : you have them on your computer as .an or .mid files...)
>> removing
>> of hard
> EEPROM...) which in "stand by mode" is supplied by the back up
> battery. The extremely low, but not null, supply current (a few nA) in
> this special mode allows years of storage without the help of the main
> P.S. But without any supply all is wiped out . When the AN1x was
> designed, flash EEPROMS vere too small and too slow, and a hard disk
> would be too huge and too expensive to store only a few tens of
> kbytes. An AN1x patch is not a sampled sound but only a few lines of
> data and instructions.
> on a computer you can try the "kamikaze way" : open your synth, turn
> on the main supply and then change your battery BUT take care of short
> circuits when you're doing that. The screwdrivers or pliers are
> obviously conductive, but the battery itself (even flat out..) too :
> don't touch anything else with any metal part. When the main supply is
> "on" the RAM is in "active mode" and does not need any other supply.
> Cheers.
> J.F.
> backup
> hard
> EEPROM...) which in "stand by mode" is supplied by the back up battery.
> The extremely low, but not null, supply current (a few nA) in this
> special mode allows years of storage without the help of the main P.S.
> But without any supply all is wiped out . When the AN1x was designed,
> flash EEPROMS vere too small and too slow, and a hard disk would be too
> huge and too expensive to store only a few tens of kbytes. An AN1x patch
> is not a sampled sound but only a few lines of data and instructions.
> a computer you can try the "kamikaze way" : open your synth, turn on the
> main supply and then change your battery BUT take care of short circuits
> when you're doing that. The screwdrivers or pliers are obviously
> conductive, but the battery itself (even flat out..) too : don't touch
> anything else with any metal part. When the main supply is "on" the RAM
> Cheers.
> J.F.
> >> Hi all,
> I
> >> Thanks,
> >> Jérôme
> but
> no
> >>> Greetz, Boogie.
> >> Jérôme St-Pierre
Jérôme St-Pierre
2011-03-13 by Nathanael King
> Damn, I am dumb! Sorry for polluting your mailboxes but the answer wasjust
> on this thread. I think I just searched for the word "backup" and didn'tbackup
> find anything so I posted my question here.
> Van already answered all my questions below:
> "BTW, you can remove/replace the battery without losing patches in memory,
> by leaving the power supply plugged in and the power on while doing the
> battery swap".
> I will try that since I don't even have a MIDI interface...
> On Sat, Mar 12, 2011 at 8:14 PM, Jerome St-Pierre
>> before changing the battery.hard
>> drive? Or are they really kept loaded in memory with the battery?I
>>> Hi all,
>>> would just like to be sure...but
>>> Thanks,
>>> Jérôme
>>>> not 100%. I bought first Renata CR2450N (is that N the difference?) andno
>>>> way to put that into the holder![Non-text portions of this message have been removed]
>>>> Greetz, Boogie.
>>> Jérôme St-Pierre
>> Jérôme St-Pierre
> Jérôme St-Pierre
2011-03-13 by Jelli Philippe
On 12 Mar 2011, at 20:23, Jerome St-Pierre wrote:
> Damn, I am dumb! Sorry for polluting your mailboxes but the answer was just
> battery swap".
>>> Hi all,
>>> Thanks,
>>> J�r�me
>>>> Greetz, Boogie.
>>> J�r�me St-Pierre
>> J�r�me St-Pierre
> J�r�me St-Pierre
____________________________________
Philippe Jelli � architecte
140 chauss�e de Haecht � 1030 Bruxelles
T�l & Fax : 02 503 06 57
Gsm : 0486 76 36 19
philippe.jelli@...
2011-03-13 by Peter Korsten
> "BTW, you can remove/replace the battery without losing patches in memory,There's a reason this is called the "kamikaze method": if you
> battery swap".
2011-03-14 by jody
--- In AN1x-list@yahoogroups.com, Jelli Philippe <philippe.jelli@...> wrote:
> FWIW, I replaced my AN1x battery 2 days ago, and I didn't loose any of the patches
> (the 'battery low' message was the first reason I subscribed to this list btw)
> I did a memory backup with Sysex Librarian first (working great btw)
> but I didn't had to use it to restore the memory afterwards.
> better have an electrical screwdriver though, because there are 33 of those !
> philippe
> > battery swap".
> >>> Hi all,
> >>> Thanks,
> >>> Jérôme
> >>>> Greetz, Boogie.
> >>> Jérôme St-Pierre
> >> Jérôme St-Pierre
> > Jérôme St-Pierre
> > Yahoo! Groups Links
> Philippe Jelli architecte
> 140 chaussée de Haecht 1030 Bruxelles
> Tél & Fax : 02 503 06 57
> Gsm : 0486 76 36 19
> philippe.jelli@...
2011-05-25 by Jerome St-Pierre
On Sun, Mar 13, 2011 at 3:38 AM, Nathanael King <nate@...> wrote:
> Just fyi having replaced batteries on other synths previously - if you have
> patches on your an1x you REALLY don't want to lose, id recommend buying a
> cheap usb/midi cable (under $10 on evilbay) and just downloading them all
> to
> an1xedit.
> In theory, if you leave the machine on, your patches will not be lost, but
> if it drops power or something shorts you could be totally messed over.
> Just saying its $10 that's totally worth it for transferring patces and id
> hate to lose some of mine....
> On Mar 12, 2011 9:33 PM, "Jerome St-Pierre" <jeromestpierre@...>
> just
> memory,
> > battery swap".
> backup
> removing
> hard
> >>> Hi all,
> I
> >>> Thanks,
> >>> J�r�me
> but
> and
> no
> >>>> Greetz, Boogie.
> >>> J�r�me St-Pierre
> >> J�r�me St-Pierre
> > J�r�me St-Pierre
> > Yahoo! Groups Links
J�r�me St-Pierre
