Triggering the AN1X Step Sequencer from an External Keyboard
2010-01-27 by edzealous
Index last updated: 2026-04-05 19:03 UTC
Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible?
2010-01-28 by edzealous
--- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@...> wrote: > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. Many thanks, Steve
2010-01-29 by Gerald Raucamp
Hello, On Thu Jan 28 2010, edzealous <edzealous@...> wrote: > > > --- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@...> wrote: > > > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > > > > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. > > Many thanks, > > Steve My understanding of the sequencer is that it can only be triggered from the keyboard. I remember coming across some posts, either on this list, or just out there on the internets on the same subject. The sequencer will send out midi data, but it cannot be triggered over midi. Check the AN1x manual starting from page 37 (english version). There's no mention of MIDI-triggered sequencing, only keyboard based triggering. Hope to have helped. Kind regards, Gerald
2010-01-29 by jammie
read the manual if the keyboard can trigger the sequence the midi notes should also i know you can set the clock to external audio so ythat it tracks in time to an drum machine or external sequencer but it will only play the sequence loaded for that preset it cant control the sequencer so that you can change it on the fly it will only play the sequence thats in memory you can change the sequence but it will only play the sequence that is already programed that you change to your problem is that your playing the notes on the ti trying to trigger the ti sound to the an1x sequence it would be all right if you played the an1x triggering the ti as when you play the notes on the an1x the ti will play the sequence notes of the an1x output you would need the midi out into the midi in of the ti by trying to do it with the ti is that you are pressing the notes that are trigering the an1x which sequence is running but becuase you are holding down the notes on the ti the sound is playing but not the sequence this is becuase the ti cant retrigger notes that are already pressed this is imposible for any keyboard to do have you tried switching the ti to omni off so that it oly responds to external midi so that a external source can control the the synth and not the onboard keyboard i dont have a ti but i can do this on the quasimidi 309 drummachine synth
To: AN1x-list@yahoogroups.com
Sent: Friday, January 29, 2010 9:10 AM
Subject: Re: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard
Hello,
> Many thanks,
> Steve
triggering.
Kind regards,
Gerald
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.432 / Virus Database: 271.1.1/2653 - Release Date: 01/28/10 14:55:00
[Non-text portions of this message have been removed]2010-01-31 by edzealous
Hey thanks for the all the info dudes. I actually got this working (sort of) today. I'll post up all the correct settings tomorrow when i'm in front of the keys, but it was setting the TI to 'Soft Thru'that got it working. The only problem is that though the sequence will trigger from the TI, i'm able to play over the sequence, whereas if I triggered it from the AN1X I wouldn't. The only way I can fix this is if I set the Seq to 'Hold' which I'd rather not do as I can't figure out how I'd stop it from the TI..... All these problems because the £1850 TI doesn't have a bleedin step sequencer! Thanks again, Steve --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> > read the manual if the keyboard can trigger the sequence the midi notes should also i know you can set the clock to external audio so ythat it tracks in time to an drum machine or external sequencer > > but it will only play the sequence loaded for that preset it cant control the sequencer so that you can change it on the fly it will only play the sequence thats in memory you can change the sequence but it will only play the sequence that is already programed that you change to > > your problem is that your playing the notes on the ti trying to trigger the ti sound to the an1x sequence > > it would be all right if you played the an1x triggering the ti as when you play the notes on the an1x the ti will play the sequence notes of the an1x output you would need the midi out into the midi in of the ti > > by trying to do it with the ti is that you are pressing the notes that are trigering the an1x which sequence is running but becuase you are holding down the notes on the ti the sound is playing but not the sequence this is becuase the ti cant retrigger notes that are already pressed this is imposible for any keyboard to do > > have you tried switching the ti to omni off so that it oly responds to external midi so that a external source can control the the synth and not the onboard keyboard i dont have a ti but i can do this on the quasimidi 309 drummachine synth > ----- Original Message ----- > From: Gerald Raucamp > To: AN1x-list@yahoogroups.com > Sent: Friday, January 29, 2010 9:10 AM > Subject: Re: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > Hello, > > On Thu Jan 28 2010, edzealous <edzealous@...> wrote: > > > > > > --- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@> wrote: > > > > > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > > > > > > > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. > > > > Many thanks, > > > > Steve > > My understanding of the sequencer is that it can only be triggered from > the keyboard. I remember coming across some posts, either on this list, > or just out there on the internets on the same subject. > > The sequencer will send out midi data, but it cannot be triggered over > midi. Check the AN1x manual starting from page 37 (english version). > There's no mention of MIDI-triggered sequencing, only keyboard based > triggering. > > Hope to have helped. > > Kind regards, > > Gerald > > > > > > > ------------------------------------------------------------------------------ > > > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 8.5.432 / Virus Database: 271.1.1/2653 - Release Date: 01/28/10 14:55:00 > > > [Non-text portions of this message have been removed] >
2010-02-01 by audiomad99@aol.com
whew!!! that stuff gets confusing
Sent: Sat, Jan 30, 2010 8:26 pm
Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard
Thanks again,
Steve
> Hello,
> > Many thanks,
> > Steve
> triggering.
> Kind regards,
> Gerald
[Non-text portions of this message have been removed]2010-02-07 by edzealous
Indeed it does, frying my head right now.... I was wondering one final thing.... Is it possible to use my Virus TI to send Midi CC data to stop the sequencer on the AN1X??? Just to explain my problem: I can currently set this up in two ways: 1) If keep the An1X sequencer set 'hold' it operates the way I want (ie: I can't play over the sequence) but I can't figure out how to stop the sequence. 2) An1X is not set to 'hold'. When its set this way I can stop the sequence when I want but when I play a sequence from the Virus TI it plays whatever note i'm playing as well as the sequence. Basically I want to hit a key on the Virus and trigger a sequence on the AN1X and then be able to stop it again from the Virus. Is this possible? and if so any ideas how I can do it???? Again, many thanks for any help you can offer. Best wishes Steve --- In AN1x-list@yahoogroups.com, audiomad99@... wrote:
> > > whew!!! that stuff gets confusing > > > > > > > > > -----Original Message----- > From: edzealous <edzealous@...> > To: AN1x-list@yahoogroups.com > Sent: Sat, Jan 30, 2010 8:26 pm > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > Hey thanks for the all the info dudes. I actually got this working (sort of) today. I'll post up all the correct settings tomorrow when i'm in front of the keys, but it was setting the TI to 'Soft Thru'that got it working. The only problem is that though the sequence will trigger from the TI, i'm able to play over the sequence, whereas if I triggered it from the AN1X I wouldn't. The only way I can fix this is if I set the Seq to 'Hold' which I'd rather not do as I can't figure out how I'd stop it from the TI..... > All these problems because the £1850 TI doesn't have a bleedin step sequencer! > > Thanks again, > > Steve > > --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > read the manual if the keyboard can trigger the sequence the midi notes should also i know you can set the clock to external audio so ythat it tracks in time to an drum machine or external sequencer > > > > but it will only play the sequence loaded for that preset it cant control the sequencer so that you can change it on the fly it will only play the sequence thats in memory you can change the sequence but it will only play the sequence that is already programed that you change to > > > > your problem is that your playing the notes on the ti trying to trigger the ti sound to the an1x sequence > > > > it would be all right if you played the an1x triggering the ti as when you play the notes on the an1x the ti will play the sequence notes of the an1x output you would need the midi out into the midi in of the ti > > > > by trying to do it with the ti is that you are pressing the notes that are trigering the an1x which sequence is running but becuase you are holding down the notes on the ti the sound is playing but not the sequence this is becuase the ti cant retrigger notes that are already pressed this is imposible for any keyboard to do > > > > have you tried switching the ti to omni off so that it oly responds to external midi so that a external source can control the the synth and not the onboard keyboard i dont have a ti but i can do this on the quasimidi 309 drummachine synth > > ----- Original Message ----- > > From: Gerald Raucamp > > To: AN1x-list@yahoogroups.com > > Sent: Friday, January 29, 2010 9:10 AM > > Subject: Re: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > Hello, > > > > On Thu Jan 28 2010, edzealous <edzealous@> wrote: > > > > > > > > > --- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@> wrote: > > > > > > > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > > > > > > > > > > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. > > > > > > Many thanks, > > > > > > Steve > > > > My understanding of the sequencer is that it can only be triggered from > > the keyboard. I remember coming across some posts, either on this list, > > or just out there on the internets on the same subject. > > > > The sequencer will send out midi data, but it cannot be triggered over > > midi. Check the AN1x manual starting from page 37 (english version). > > There's no mention of MIDI-triggered sequencing, only keyboard based > > triggering. > > > > Hope to have helped. > > > > Kind regards, > > > > Gerald > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > No virus found in this incoming message. > > Checked by AVG - www.avg.com > > Version: 8.5.432 / Virus Database: 271.1.1/2653 - Release Date: 01/28/10 14:55:00 > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] >
2010-02-07 by jammie
look at the cc parameter that switches the sequencer on and off and assign it to a button on the virus as a continuios controller if you can do that on the virus dont know
Sent: Sunday, February 07, 2010 3:43 PM
Best wishes
Steve
> Thanks again,
> Steve
> > Hello,
> > > Many thanks,
> > > Steve
> > triggering.
> > Kind regards,
> > Gerald
Version: 8.5.435 / Virus Database: 271.1.1/2673 - Release Date: 02/07/10 07:22:00
[Non-text portions of this message have been removed]2010-02-08 by Ed Edwards
Sorry about the delayed reply. I think it has something to do with a different mode setting on the keyboard. If you have the smaller accompaniment manual that came with the AN1x it describes this second mode and what it is able to do. _____
From: AN1x-list@yahoogroups.com [mailto:AN1x-list@yahoogroups.com] On Behalf Of edzealous Sent: Saturday, January 30, 2010 8:27 PM To: AN1x-list@yahoogroups.com Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard Hey thanks for the all the info dudes. I actually got this working (sort of) today. I'll post up all the correct settings tomorrow when i'm in front of the keys, but it was setting the TI to 'Soft Thru'that got it working. The only problem is that though the sequence will trigger from the TI, i'm able to play over the sequence, whereas if I triggered it from the AN1X I wouldn't. The only way I can fix this is if I set the Seq to 'Hold' which I'd rather not do as I can't figure out how I'd stop it from the TI..... All these problems because the £1850 TI doesn't have a bleedin step sequencer! Thanks again, Steve --- In AN1x-list@yahoogrou <mailto:AN1x-list%40yahoogroups.com> ps.com, "jammie" <jammie.emma@...> wrote: > > read the manual if the keyboard can trigger the sequence the midi notes should also i know you can set the clock to external audio so ythat it tracks in time to an drum machine or external sequencer > > but it will only play the sequence loaded for that preset it cant control the sequencer so that you can change it on the fly it will only play the sequence thats in memory you can change the sequence but it will only play the sequence that is already programed that you change to > > your problem is that your playing the notes on the ti trying to trigger the ti sound to the an1x sequence > > it would be all right if you played the an1x triggering the ti as when you play the notes on the an1x the ti will play the sequence notes of the an1x output you would need the midi out into the midi in of the ti > > by trying to do it with the ti is that you are pressing the notes that are trigering the an1x which sequence is running but becuase you are holding down the notes on the ti the sound is playing but not the sequence this is becuase the ti cant retrigger notes that are already pressed this is imposible for any keyboard to do > > have you tried switching the ti to omni off so that it oly responds to external midi so that a external source can control the the synth and not the onboard keyboard i dont have a ti but i can do this on the quasimidi 309 drummachine synth > ----- Original Message ----- > From: Gerald Raucamp > To: AN1x-list@yahoogrou <mailto:AN1x-list%40yahoogroups.com> ps.com > Sent: Friday, January 29, 2010 9:10 AM > Subject: Re: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > Hello, > > On Thu Jan 28 2010, edzealous <edzealous@...> wrote: > > > > > > --- In AN1x-list@yahoogrou <mailto:AN1x-list%40yahoogroups.com> ps.com, "edzealous" <edzealous@> wrote: > > > > > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > > > > > > > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. > > > > Many thanks, > > > > Steve > > My understanding of the sequencer is that it can only be triggered from > the keyboard. I remember coming across some posts, either on this list, > or just out there on the internets on the same subject. > > The sequencer will send out midi data, but it cannot be triggered over > midi. Check the AN1x manual starting from page 37 (english version). > There's no mention of MIDI-triggered sequencing, only keyboard based > triggering. > > Hope to have helped. > > Kind regards, > > Gerald > > > > > > > ---------------------------------------------------------- > > > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 8.5.432 / Virus Database: 271.1.1/2653 - Release Date: 01/28/10 14:55:00 > > > [Non-text portions of this message have been removed] > No virus found in this incoming message. Checked by AVG - www.avg.com Version: 9.0.733 / Virus Database: 271.1.1/2655 - Release Date: 01/30/10 02:35:00 [Non-text portions of this message have been removed]
2010-02-14 by edzealous
Thanks again for all the replies. Couldn't quite figure out how do that on the Virus but I managed a simple workaround for this one: If I trigger 'All Notes Off' on the Virus the sequencer stops....voila! Having one final problem though. I'm trying to configure the set up so that when I make program changes on the Virus the AN1X changes with it. i.e: say I change from RAM-A 0 to RAM-A 1 on the Virus, I want the AN1X to change from 000 to 001. At the moment it works back to front, I can change a preset on the AN1X and the Virus will change too.....but not the other way around.....which is what I want. However i'm not quite sure whether this is a setting on the Virus or the AN1X. Any ideas??? --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> > look at the cc parameter that switches the sequencer on and off and assign it to a button on the virus as a continuios controller if you can do that on the virus dont know > ----- Original Message ----- > From: edzealous > To: AN1x-list@yahoogroups.com > Sent: Sunday, February 07, 2010 3:43 PM > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > Indeed it does, frying my head right now.... I was wondering one final thing.... Is it possible to use my Virus TI to send Midi CC data to stop the sequencer on the AN1X??? Just to explain my problem: I can currently set this up in two ways: > 1) If keep the An1X sequencer set 'hold' it operates the way I want (ie: I can't play over the sequence) but I can't figure out how to stop the sequence. > 2) An1X is not set to 'hold'. When its set this way I can stop the sequence when I want but when I play a sequence from the Virus TI it plays whatever note i'm playing as well as the sequence. > > Basically I want to hit a key on the Virus and trigger a sequence on the AN1X and then be able to stop it again from the Virus. Is this possible? and if so any ideas how I can do it???? > > Again, many thanks for any help you can offer. > > Best wishes > Steve > --- In AN1x-list@yahoogroups.com, audiomad99@ wrote: > > > > > > whew!!! that stuff gets confusing > > > > > > > > > > > > > > > > > > -----Original Message----- > > From: edzealous <edzealous@> > > To: AN1x-list@yahoogroups.com > > Sent: Sat, Jan 30, 2010 8:26 pm > > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > Hey thanks for the all the info dudes. I actually got this working (sort of) today. I'll post up all the correct settings tomorrow when i'm in front of the keys, but it was setting the TI to 'Soft Thru'that got it working. The only problem is that though the sequence will trigger from the TI, i'm able to play over the sequence, whereas if I triggered it from the AN1X I wouldn't. The only way I can fix this is if I set the Seq to 'Hold' which I'd rather not do as I can't figure out how I'd stop it from the TI..... > > All these problems because the £1850 TI doesn't have a bleedin step sequencer! > > > > Thanks again, > > > > Steve > > > > --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > > > read the manual if the keyboard can trigger the sequence the midi notes should also i know you can set the clock to external audio so ythat it tracks in time to an drum machine or external sequencer > > > > > > but it will only play the sequence loaded for that preset it cant control the sequencer so that you can change it on the fly it will only play the sequence thats in memory you can change the sequence but it will only play the sequence that is already programed that you change to > > > > > > your problem is that your playing the notes on the ti trying to trigger the ti sound to the an1x sequence > > > > > > it would be all right if you played the an1x triggering the ti as when you play the notes on the an1x the ti will play the sequence notes of the an1x output you would need the midi out into the midi in of the ti > > > > > > by trying to do it with the ti is that you are pressing the notes that are trigering the an1x which sequence is running but becuase you are holding down the notes on the ti the sound is playing but not the sequence this is becuase the ti cant retrigger notes that are already pressed this is imposible for any keyboard to do > > > > > > have you tried switching the ti to omni off so that it oly responds to external midi so that a external source can control the the synth and not the onboard keyboard i dont have a ti but i can do this on the quasimidi 309 drummachine synth > > > ----- Original Message ----- > > > From: Gerald Raucamp > > > To: AN1x-list@yahoogroups.com > > > Sent: Friday, January 29, 2010 9:10 AM > > > Subject: Re: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > Hello, > > > > > > On Thu Jan 28 2010, edzealous <edzealous@> wrote: > > > > > > > > > > > > --- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@> wrote: > > > > > > > > > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > > > > > > > > > > > > > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. > > > > > > > > Many thanks, > > > > > > > > Steve > > > > > > My understanding of the sequencer is that it can only be triggered from > > > the keyboard. I remember coming across some posts, either on this list, > > > or just out there on the internets on the same subject. > > > > > > The sequencer will send out midi data, but it cannot be triggered over > > > midi. Check the AN1x manual starting from page 37 (english version). > > > There's no mention of MIDI-triggered sequencing, only keyboard based > > > triggering. > > > > > > Hope to have helped. > > > > > > Kind regards, > > > > > > Gerald > > > > > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > > > > > No virus found in this incoming message. > > > Checked by AVG - www.avg.com > > > Version: 8.5.432 / Virus Database: 271.1.1/2653 - Release Date: 01/28/10 14:55:00 > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------------------ > > > > No virus found in this incoming message. > Checked by AVG - www.avg.com > Version: 8.5.435 / Virus Database: 271.1.1/2673 - Release Date: 02/07/10 07:22:00 > > > [Non-text portions of this message have been removed] >
2010-02-16 by audiomad99@aol.com
maybe its one of the midi filters on the an1X not letting it receive the command
Sent: Sun, Feb 14, 2010 1:53 pm
Any ideas???
> From: edzealous
> Best wishes
> Steve
> > Thanks again,
> > Steve
> > > Hello,
> > > > Many thanks,
> > > > Steve
> > > triggering.
> > > Kind regards,
> > > Gerald
[Non-text portions of this message have been removed]2010-02-16 by edzealous
Hey thanks again for the reply. I got an answer from Access on this one. Apparently none of the Virus line sends out Program Change messages.......agggggh! --- In AN1x-list@yahoogroups.com, audiomad99@... wrote:
> > > maybe its one of the midi filters on the an1X not letting it receive the command > > > > > > > > > > -----Original Message----- > From: edzealous <edzealous@...> > To: AN1x-list@yahoogroups.com > Sent: Sun, Feb 14, 2010 1:53 pm > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > Thanks again for all the replies. Couldn't quite figure out how do that on the Virus but I managed a simple workaround for this one: If I trigger 'All Notes Off' on the Virus the sequencer stops....voila! > > Having one final problem though. I'm trying to configure the set up so that when I make program changes on the Virus the AN1X changes with it. i.e: say I change from RAM-A 0 to RAM-A 1 on the Virus, I want the AN1X to change from 000 to 001. At the moment it works back to front, I can change a preset on the AN1X and the Virus will change too.....but not the other way around.....which is what I want. However i'm not quite sure whether this is a setting on the Virus or the AN1X. > Any ideas??? > > --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > look at the cc parameter that switches the sequencer on and off and assign it to a button on the virus as a continuios controller if you can do that on the virus dont know > > ----- Original Message ----- > > From: edzealous > > To: AN1x-list@yahoogroups.com > > Sent: Sunday, February 07, 2010 3:43 PM > > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > Indeed it does, frying my head right now.... I was wondering one final thing.... Is it possible to use my Virus TI to send Midi CC data to stop the sequencer on the AN1X??? Just to explain my problem: I can currently set this up in two ways: > > 1) If keep the An1X sequencer set 'hold' it operates the way I want (ie: I can't play over the sequence) but I can't figure out how to stop the sequence. > > 2) An1X is not set to 'hold'. When its set this way I can stop the sequence when I want but when I play a sequence from the Virus TI it plays whatever note i'm playing as well as the sequence. > > > > Basically I want to hit a key on the Virus and trigger a sequence on the AN1X and then be able to stop it again from the Virus. Is this possible? and if so any ideas how I can do it???? > > > > Again, many thanks for any help you can offer. > > > > Best wishes > > Steve > > --- In AN1x-list@yahoogroups.com, audiomad99@ wrote: > > > > > > > > > whew!!! that stuff gets confusing > > > > > > > > > > > > > > > > > > > > > > > > > > > -----Original Message----- > > > From: edzealous <edzealous@> > > > To: AN1x-list@yahoogroups.com > > > Sent: Sat, Jan 30, 2010 8:26 pm > > > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > > > > > > > Hey thanks for the all the info dudes. I actually got this working (sort of) today. I'll post up all the correct settings tomorrow when i'm in front of the keys, but it was setting the TI to 'Soft Thru'that got it working. The only problem is that though the sequence will trigger from the TI, i'm able to play over the sequence, whereas if I triggered it from the AN1X I wouldn't. The only way I can fix this is if I set the Seq to 'Hold' which I'd rather not do as I can't figure out how I'd stop it from the TI..... > > > All these problems because the ã1850 TI doesn't have a bleedin step sequencer! > > > > > > Thanks again, > > > > > > Steve > > > > > > --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > > > > > read the manual if the keyboard can trigger the sequence the midi notes should also i know you can set the clock to external audio so ythat it tracks in time to an drum machine or external sequencer > > > > > > > > but it will only play the sequence loaded for that preset it cant control the sequencer so that you can change it on the fly it will only play the sequence thats in memory you can change the sequence but it will only play the sequence that is already programed that you change to > > > > > > > > your problem is that your playing the notes on the ti trying to trigger the ti sound to the an1x sequence > > > > > > > > it would be all right if you played the an1x triggering the ti as when you play the notes on the an1x the ti will play the sequence notes of the an1x output you would need the midi out into the midi in of the ti > > > > > > > > by trying to do it with the ti is that you are pressing the notes that are trigering the an1x which sequence is running but becuase you are holding down the notes on the ti the sound is playing but not the sequence this is becuase the ti cant retrigger notes that are already pressed this is imposible for any keyboard to do > > > > > > > > have you tried switching the ti to omni off so that it oly responds to external midi so that a external source can control the the synth and not the onboard keyboard i dont have a ti but i can do this on the quasimidi 309 drummachine synth > > > > ----- Original Message ----- > > > > From: Gerald Raucamp > > > > To: AN1x-list@yahoogroups.com > > > > Sent: Friday, January 29, 2010 9:10 AM > > > > Subject: Re: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > > > > > Hello, > > > > > > > > On Thu Jan 28 2010, edzealous <edzealous@> wrote: > > > > > > > > > > > > > > > --- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@> wrote: > > > > > > > > > > > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > > > > > > > > > > > > > > > > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. > > > > > > > > > > Many thanks, > > > > > > > > > > Steve > > > > > > > > My understanding of the sequencer is that it can only be triggered from > > > > the keyboard. I remember coming across some posts, either on this list, > > > > or just out there on the internets on the same subject. > > > > > > > > The sequencer will send out midi data, but it cannot be triggered over > > > > midi. Check the AN1x manual starting from page 37 (english version). > > > > There's no mention of MIDI-triggered sequencing, only keyboard based > > > > triggering. > > > > > > > > Hope to have helped. > > > > > > > > Kind regards, > > > > > > > > Gerald > > > > > > > > > > > > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > > > > > > > > > No virus found in this incoming message. > > > > Checked by AVG - www.avg.com > > > > Version: 8.5.432 / Virus Database: 271.1.1/2653 - Release Date: 01/28/10 14:55:00 > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > No virus found in this incoming message. > > Checked by AVG - www.avg.com > > Version: 8.5.435 / Virus Database: 271.1.1/2673 - Release Date: 02/07/10 07:22:00 > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] >
woahhh interesting to hear that the virus doesnt send program changes ,....i def didnt know that
Sent: Tue, Feb 16, 2010 7:48 am
> Any ideas???
> > From: edzealous
> > Best wishes
> > Steve
> > > Thanks again,
> > > Steve
> > > > Hello,
> > > > > Many thanks,
> > > > > Steve
> > > > triggering.
> > > > Kind regards,
> > > > Gerald
[Non-text portions of this message have been removed]2010-02-17 by edzealous
Hey sorry to batter on at the same subject but one final question: Is it possible for me to make Program Changes on the AN1X with one of the footswitches/controllers??? Its just that atm i'm relying on our drummer to change programs on the AN1X during gigs (as its kept off stage) and though it works, its not an ideal scenario. Thanks again for all your time, Steve --- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@...> wrote:
> > Hey thanks again for the reply. I got an answer from Access on this one. Apparently none of the Virus line sends out Program Change messages.......agggggh! > > --- In AN1x-list@yahoogroups.com, audiomad99@ wrote: > > > > > > maybe its one of the midi filters on the an1X not letting it receive the command > > > > > > > > > > > > > > > > > > > > -----Original Message----- > > From: edzealous <edzealous@> > > To: AN1x-list@yahoogroups.com > > Sent: Sun, Feb 14, 2010 1:53 pm > > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > Thanks again for all the replies. Couldn't quite figure out how do that on the Virus but I managed a simple workaround for this one: If I trigger 'All Notes Off' on the Virus the sequencer stops....voila! > > > > Having one final problem though. I'm trying to configure the set up so that when I make program changes on the Virus the AN1X changes with it. i.e: say I change from RAM-A 0 to RAM-A 1 on the Virus, I want the AN1X to change from 000 to 001. At the moment it works back to front, I can change a preset on the AN1X and the Virus will change too.....but not the other way around.....which is what I want. However i'm not quite sure whether this is a setting on the Virus or the AN1X. > > Any ideas??? > > > > --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > > > look at the cc parameter that switches the sequencer on and off and assign it to a button on the virus as a continuios controller if you can do that on the virus dont know > > > ----- Original Message ----- > > > From: edzealous > > > To: AN1x-list@yahoogroups.com > > > Sent: Sunday, February 07, 2010 3:43 PM > > > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > Indeed it does, frying my head right now.... I was wondering one final thing.... Is it possible to use my Virus TI to send Midi CC data to stop the sequencer on the AN1X??? Just to explain my problem: I can currently set this up in two ways: > > > 1) If keep the An1X sequencer set 'hold' it operates the way I want (ie: I can't play over the sequence) but I can't figure out how to stop the sequence. > > > 2) An1X is not set to 'hold'. When its set this way I can stop the sequence when I want but when I play a sequence from the Virus TI it plays whatever note i'm playing as well as the sequence. > > > > > > Basically I want to hit a key on the Virus and trigger a sequence on the AN1X and then be able to stop it again from the Virus. Is this possible? and if so any ideas how I can do it???? > > > > > > Again, many thanks for any help you can offer. > > > > > > Best wishes > > > Steve > > > --- In AN1x-list@yahoogroups.com, audiomad99@ wrote: > > > > > > > > > > > > whew!!! that stuff gets confusing > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -----Original Message----- > > > > From: edzealous <edzealous@> > > > > To: AN1x-list@yahoogroups.com > > > > Sent: Sat, Jan 30, 2010 8:26 pm > > > > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > > > > > > > > > > > > > Hey thanks for the all the info dudes. I actually got this working (sort of) today. I'll post up all the correct settings tomorrow when i'm in front of the keys, but it was setting the TI to 'Soft Thru'that got it working. The only problem is that though the sequence will trigger from the TI, i'm able to play over the sequence, whereas if I triggered it from the AN1X I wouldn't. The only way I can fix this is if I set the Seq to 'Hold' which I'd rather not do as I can't figure out how I'd stop it from the TI..... > > > > All these problems because the ã1850 TI doesn't have a bleedin step sequencer! > > > > > > > > Thanks again, > > > > > > > > Steve > > > > > > > > --- In AN1x-list@yahoogroups.com, "jammie" <jammie.emma@> wrote: > > > > > > > > > > read the manual if the keyboard can trigger the sequence the midi notes should also i know you can set the clock to external audio so ythat it tracks in time to an drum machine or external sequencer > > > > > > > > > > but it will only play the sequence loaded for that preset it cant control the sequencer so that you can change it on the fly it will only play the sequence thats in memory you can change the sequence but it will only play the sequence that is already programed that you change to > > > > > > > > > > your problem is that your playing the notes on the ti trying to trigger the ti sound to the an1x sequence > > > > > > > > > > it would be all right if you played the an1x triggering the ti as when you play the notes on the an1x the ti will play the sequence notes of the an1x output you would need the midi out into the midi in of the ti > > > > > > > > > > by trying to do it with the ti is that you are pressing the notes that are trigering the an1x which sequence is running but becuase you are holding down the notes on the ti the sound is playing but not the sequence this is becuase the ti cant retrigger notes that are already pressed this is imposible for any keyboard to do > > > > > > > > > > have you tried switching the ti to omni off so that it oly responds to external midi so that a external source can control the the synth and not the onboard keyboard i dont have a ti but i can do this on the quasimidi 309 drummachine synth > > > > > ----- Original Message ----- > > > > > From: Gerald Raucamp > > > > > To: AN1x-list@yahoogroups.com > > > > > Sent: Friday, January 29, 2010 9:10 AM > > > > > Subject: Re: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > > > > > > > > > > > > > > > > > > > Hello, > > > > > > > > > > On Thu Jan 28 2010, edzealous <edzealous@> wrote: > > > > > > > > > > > > > > > > > > --- In AN1x-list@yahoogroups.com, "edzealous" <edzealous@> wrote: > > > > > > > > > > > > > > Hi, I was wondering if I can trigger the step sequencer patterns in my AN1X with an external Synth (ext synth being the sound generator). Specifically i'm trying to trigger step seq patterns in an AN1X from a Virus TI and have them sound on the Virus TI. At the moment I can only seem to trigger them if I use the AN1X keyboard. Any ideas if this is even possible? > > > > > > > > > > > > > > > > > > > Sorry to re-post but does anyone know if this can be done??? Trying to sort this out urgently for a few gigs happing in the next two weeks and I'm no further on. I'm comming to the conclusion that its impossible but it would be great to get a definitive answer. > > > > > > > > > > > > Many thanks, > > > > > > > > > > > > Steve > > > > > > > > > > My understanding of the sequencer is that it can only be triggered from > > > > > the keyboard. I remember coming across some posts, either on this list, > > > > > or just out there on the internets on the same subject. > > > > > > > > > > The sequencer will send out midi data, but it cannot be triggered over > > > > > midi. Check the AN1x manual starting from page 37 (english version). > > > > > There's no mention of MIDI-triggered sequencing, only keyboard based > > > > > triggering. > > > > > > > > > > Hope to have helped. > > > > > > > > > > Kind regards, > > > > > > > > > > Gerald > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > > > > > > > > > > > > > No virus found in this incoming message. > > > > > Checked by AVG - www.avg.com > > > > > Version: 8.5.432 / Virus Database: 271.1.1/2653 - Release Date: 01/28/10 14:55:00 > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > > > > > No virus found in this incoming message. > > > Checked by AVG - www.avg.com > > > Version: 8.5.435 / Virus Database: 271.1.1/2673 - Release Date: 02/07/10 07:22:00 > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > >
2010-02-19 by Andrea TONI
Ummm ! this is very strange i have a virus KC at home and i will check tonight but in the MIDI page of the virus C family pdf manual P_change is there rx and tx page 187 of this pdf http://www.access-music.de/api/download/dlid/218/alternate/0/User%20manual%20for%20Virus%20C%20Series%20in%20English maybe only the modules dont but the kbd does ? i will check tonight and let u know Andrea >>> woahhh interesting to hear that the virus doesnt send program changes ,....i def didnt know that
-----Original Message----- From: edzealous <edzealous@...> To: AN1x-list@yahoogroups.com Sent: Tue, Feb 16, 2010 7:48 am Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard Hey thanks again for the reply. I got an answer from Access on this one. Apparently none of the Virus line sends out Program Change messages.......agggggh!
2010-02-20 by atmosfere_sonore
i have just tried now with the an1x and the jd800 no PC in single or in multi mode ! very bad ... so not even the Virus KC send PC ! even if it is marked as a yes on the midi specs Andrea --- In AN1x-list@...m, Andrea TONI <atoni@...> wrote:
> > Ummm ! > > this is very strange > i have a virus KC at home and i will check tonight > but in the MIDI page of the virus C family pdf manual P_change is there rx and tx > > page 187 of this pdf > > http://www.access-music.de/api/download/dlid/218/alternate/0/User%20manual%20for%20Virus%20C%20Series%20in%20English > > maybe only the modules dont but the kbd does ? > i will check tonight and let u know > > Andrea > > >>> > > woahhh interesting to hear that the virus doesnt send program changes ,....i def didnt > know that > > -----Original Message----- > From: edzealous <edzealous@...> > To: AN1x-list@yahoogroups.com > Sent: Tue, Feb 16, 2010 7:48 am > Subject: [AN1x] Re: Triggering the AN1X Step Sequencer from an External Keyboard > > Hey thanks again for the reply. I got an answer from Access on this one. > Apparently none of the Virus line sends out Program Change messages.......agggggh! >
