replacement power adaptor
2010-01-04 by spaceanimals
Index last updated: 2026-03-31 13:41 UTC
2010-01-04 by Bob S.
To: AN1x-list@yahoogroups.com
Sent: Monday, January 04, 2010 7:22 AM
Subject: [AN1x] replacement power adaptor
Has anyone used a PA 130 as a replacement power adaptor for the AN1x? It's supposed to be a replacement for the PA3B but I don't want to take any chances.
Thank you.
Jim
2010-01-04 by Malte Krug
> Power outputs match....12V at 1A. There is no reason why it should not
> work. I use several PA130 style 12V adapters to replace the original
> supplies on my other synths....
> The adapters look different because the original was a step down
> transformer based design and the PA130 is a switching power supply based
> design....
> Bob
> El Segundo, CA
> From: spaceanimals
> any chances.
> Thank you.
> Jim
2010-01-05 by Jeff
>You can take ANY DC power supply, 12 V - 700 mA (minimum !) output. On
> take any chances.
> Thank you.
> Jim
2010-01-05 by Oliver Fairhall
> Hello Jimmy!
>> take any chances.
> the connector the + is the center pin, the - the outer sleeve. The kind
> of supply you can find in any electronics shop or hardware store,
> cheaper than the Yamaha branded one. Be careful with Yamaha keyboards
> supplies, they can be very different (voltage and current ratings).
>> Thank you.
>> Jim
> J.F.
> Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
> http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
2010-01-05 by Jeff
> This is a good thread for me. The adapter which came with my synth seems
> to be under rated for the job. I didn't find the current requirements in
> the AN1x manual. Perhaps I didn't look hard enough.
> Cheers,
> Oli
> Jeff wrote:
>> Hello Jimmy!
>>> take any chances.
>>> Thank you.
>>> Jim
>> J.F.
>> Yahoo! Groups Links
