Index last updated: 2026-03-31 01:25 UTC
AN1x Battery CR 2450 y vs n
2009-11-11 by ras_mynameisnottaken
Hi Folks,
After 12 years of service, the lithium battery finally started to die. So I got a replacement battery model CR 2450n.
The battery looks identical except I noticed that it doesn't fit in quite as well as the original. The original in my AN1x was a CR 2450y. I could not find a 2450y, perhaps Yamaha carries these?
The diameter seems the same between the two, but one must be slightly thicker or something as I was unable to get the clip that olds the battery in place to click fully back on the way the y model battery did.
This doesn't seem to affect the function of the battery at all and its still pretty secure as it takes a jeweler's screwdriver to pop-out, just avoid knocking around the synth incase the battery were to pop out (this is always good advice anyway).
Just thought I would put this on the record for future battery swappers that have the WTF moment like I did :)
Re: AN1x Battery CR 2450 y vs n
2009-11-17 by advanced_parapsychiatry
I'm about to have that very same WTF moment.
I just finished replacing a few of the failing keys on a very "used" AN1x I picked up and as soon as I had it all back together I got the Battery Low message. Bah.
I couldn't find a CR2450y anywhere, either so I'm about to see how it fits tonight.
Will report on my progress.
--- In AN1x-list@yahoogroups.com, "ras_mynameisnottaken" <letterzbox@...> wrote:
> Hi Folks,
Re: [AN1x] Re: AN1x Battery CR 2450 y vs n
2009-11-18 by audiomad99@aol.com
sorry to hear about the dead battery but an alternative would be great!!!! thanks for the info
To: AN1x-list@yahoogroups.com
Sent: Tue, Nov 17, 2009 12:45 pm
Subject: [AN1x] Re: AN1x Battery CR 2450 y vs n
> Hi Folks,
RE: [AN1x] Re: AN1x Battery CR 2450 y vs n
2009-11-19 by emmanuel vincent
www.Ruedespiles.com
Date: Wed, 18 Nwww.Ruedespiles.comov 2009 12:33:48 -0500
Subject: Re: [AN1x] Re: AN1x Battery CR 2450 y vs n
> Hi Folks,
Messenger d�barque dans Hotmail ! Essayez-le !
http://www.windowslive.fr/hotmail/web-messenger/
[AN1x] Re: AN1x Battery CR 2450 y vs n - Doesn't Matter!
2009-11-19 by Teddy Ballgame
Just an update on my battery replacement endeavour. I Put in a non "Y" standard Energizer CR2450 and it popped right in with no problem. Fits securely and, for sure, is not going anywhere.
> -----Original Message-----
> From: advanced_parapsychiatry <betteroffted@...>
> --- In AN1x-list@yahoogroups.com, "ras_mynameisnottaken" <letterzbox@> wrote:
> > Hi Folks,
Re: [AN1x] Re: AN1x Battery CR 2450 y vs n - Doesn't Matter!
2009-11-19 by audiomad99@aol.com
AWESOME info !!!!
thanks for posting your findings!!! ,...
Sent: Thu, Nov 19, 2009 9:23 am
Subject: [AN1x] Re: AN1x Battery CR 2450 y vs n - Doesn't Matter!
> > Hi Folks,
