Index last updated: 2026-03-31 01:25 UTC
Time has come
Time has come
2009-11-09 by YE DI
Hi every AN-guy out there,
I'm sort of old newbie :) I proudly own the fantastic AN1X for about a year, but am still experimenting, making just slow steps in its discovery. I have neither modified any factory patch, nor used the computer editor. Yes, You may smile now :) I'm not that computer nut young guy, and just ignored the save-through facility, tweaking the synth in that old fashioned 70's style. Anyway, yesterday my beloved AN1X showed me the "Battery Low" message. Time has come.
I've got a specialist to exchange the batteries, but of course I'll lose the patches. You may suppose, they are the original factory presets /Relaxx, Terraform, etc/.
Now I'd like to ask for some assistance, guys. What do I need? Some simple, commonplace pieces of information.
1. Which software should I use for dumping the patches? Your advice? Where can I get it from? Is there a sort of universal software applicable for other synths, too?
2. Where can I find a step-by-step description for saving/loading patches? Sort of "Quick Sysex Tutorial for Dummies" :)
3. For any case, where can I find/download the original patches?
Any hint would be much appreciated
Thank You in advance for Your kind help and for maintaining this great community!
Yours, Y
Re: [AN1x] Time has come
2009-11-09 by Jeff
Hello !
see in your text :
If you only want to store/load sound files you can use MIDIox which is a
freeware easily found on the web. It cannot modify anything, or more
precisely it is not designed for this purpose. If you know perfectly all
the sysex codes of the AN1x you can edit your data as a text, change the
values (hexadecimal) and load the new file back to the synth but i
suppose it is an awful job...
In the manual of course...
First try to save all the memory content of your synth using one or the
other software, and *only after* try to load other sound files. In
emergency case you have a function in the test mode that restores the
complete factory sound set. Hidden somewhere in an EPROM it is then
stored in the RAM...
Do like that :
* turn the power "on" while holding the "7","8","9" keys together in
"the program change" keypad
* then "Fact. set? (1-9)" will appear on the LCD display
* choose one of the 9 options (1 = voices 1 to 64, 2 = voices 65 to
128, 3 = all the voices...i don't remember the others), for exemple 2
* press the "2" key, and then "YES/ENTER" : that's done! Of course
if you type "NO" you'll go back to the previous step.
I suppose that your AN1x is a second hand, so the previous owner could
have stored his own sounds : the factory set will only restore factory
sounds. If you like them, everyting is lost. So IMHO it is more secure
to store all the sounds on your computer using MIDIox or, of course,
AN1x edit.
Cheers!
J.F.
> community!
> Yours, Y
RE: [AN1x] Time has come
2009-11-10 by Ed Edwards
Jeff has given you the best answer. Save what you've got because you don't
know if it's been tweaked and it's just the factory names that are original.
One thing I might add is that there were more than one set of factory
patches. Probably doesn't apply to you but IIRC the European versions had
some completely different sets. If you dig around in the files section of
this you'll find the UK voice sets.
_____
From: AN1x-list@yahoogroups.com [mailto:AN1x-list@yahoogroups.com] On Behalf
Of YE DI
Sent: Monday, November 09, 2009 6:35 AM
To: AN1x-list@yahoogroups.com
Subject: [AN1x] Time has come
has come.
Terraform, etc/.
other synths, too?
community!
Yours, Y
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.698 / Virus Database: 270.14.55/2490 - Release Date: 11/08/09
14:39:00
