aftertouch sensitivity change ?
2009-05-18 by nochtanseenspecht
Greets An1xers,
Due to circumstances, i am using the an1x as master keys at the moment.
the problem is that the aftertouch seems rather sensitive..
is there anyway to change that ? i didn't find a way so far..
i know velocity sens can be changed, so i was hoping aftertouch too..
thanks, david
Re: aftertouch sensitivity change ?
2009-05-18 by Bob S.
It can be done in any one of 3 ways:
(1) Adjust the amount of modulation the synthesizer used to generate the sound, applies to the parameter, usually in a modulation matrix where you selected to use after touch as the source of modulation.
(2) If you have a midi processor box, such as one inside the midi switch MX-8, you can take a midi parameter and scale it. Give less gain to after touch.
(3) Open the AN1x if you feel proficient to do so. On the keyboard circuit board, there are 2 small pots, one for after touch gain and one for the offset value once the AT kicks in. I adjusted mine for higher sensitivity because that's how I like it....
Bob
El Segundo, CA
BTW - I just sold my AN1x....but still have a PLG150-AN in my CS6X..
--- In AN1x-list@yahoogroups.com, "nochtanseenspecht" <nochtanseenspecht@...> wrote:
> Greets An1xers,
> thanks, david
Re: [AN1x] Re: aftertouch sensitivity change ?
2009-05-19 by Luc Hogie
Is it possible to change the sensitivity of velocity in the same way
that you do with aftertouch? Because "normal" velocity is too light to me
and the "hard" one is too hard.
> Bob
> El Segundo, CA
> --- In AN1x-list@yahoogroups.com <mailto:AN1x-list%40yahoogroups.com>,
> > Greets An1xers,
> > thanks, david
