Can the An1x load AN200 sounds ? 2009-03-15 by moroeat Hello Can the An1x load AN200 sounds ? Greets Moroe
Re: Can the An1x load AN200 sounds ? 2009-03-16 by XOIO Aparrently it can, however it has to be done via the PC editor software, so that it can make the compatability alterations required. You can't simply load up an AN200 file, as even the .extensions are different between the machines it think. Xoio
