'Recieve error!'
2008-02-25 by mikeleonhart
2008-02-25 by Jon
>Are you using a Mac or PC? What type of MIDI Interface? Are you performing a bulk transfer
> I keep recieving that message whenever i try to send a sound from AN1X
> to the AN1X editor, help?
--- In AN1x-list@yahoogroups.com, "Jon" <jondl_2000@...> wrote:
> --- In AN1x-list@yahoogroups.com, "mikeleonhart" <mikeleonhart@>
AN1X
> or one sound at a time? Are you initiating the transfer from
AN1xEdit or are you trying to
> initiate the dump from the AN1x front panel controls?
2008-02-26 by Summa
On 25 Feb 2008 at 19:07, mikeleonhart wrote:
> Im using a PC
> trying to send 1 individual sound to the Yamaha AN1X editor for
> editing.
> I'm pressing the request button on the editor, to transfer to sound to
> it, however it comes up with 'recieve error'
> Im using a MIDI in MIDI out cable directly to the AN1X
> AN1X
> Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
> http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
CZ/VZ mailing list : http://groups.yahoo.com/group/CZsynth
FMHeaven mailing list : http://groups.yahoo.com/group/fmheaven/
FS1R mailing list : http://www.ampfea.org/mailman/listinfo/fss-list
Vokator mailing list : http://groups.yahoo.com/group/vokator
http://www.summasounds.de/
2008-02-26 by mikeleonhart
--- In AN1x-list@yahoogroups.com, "Summa" <flotorian@...> wrote:
> A Joystick Port MIDI Cable? You hopefully connected MIDI-IN with
> Cable-Out and Cable-In with With MIDI Out?
> > Im using a PC
> > editing.
sound to
<mikeleonhart@>
from
> > AN1X
> > Yahoo! Groups Links
> FS1R mailing list :
2008-02-26 by Gerald Raucamp
> Yes I did, Midi In, to midi out, and visa vie.Just out of curiosity... did you select the correct midi channels on the
> Im using a USB cable to do so..
> I'm still not sure why i cannot do transfer.
2008-02-26 by Jon
>Gerarlds suggestions are very practical - double check the MIDI In & Out cables are
> AN1x and on your PC?
> Can you retrieve sounds from the AN1x, instead of just editing stuff
> straight from the editor? (I may have missed a bit of workflow, pardon
> me if that has come up already)
> I know I had some trouble getting my AN1x to listen to midi and send
> midi.. had to switch of Local (but that was for getting it to make sound
> coming from a midi sequencer in a GNU/Linux environment).
>wrote:
> --- In AN1x-list@yahoogroups.com, Gerald Raucamp <yahoogroups@>
> >on the
> > AN1x and on your PC?stuff
> > straight from the editor? (I may have missed a bit of workflow,pardon
> > me if that has come up already)send
> > midi.. had to switch of Local (but that was for getting it tomake sound
> > coming from a midi sequencer in a GNU/Linux environment).& Out cables are
> connected to the correct ports and the MIDI Channels correspond assuggested.
>you mentioned it was a USB
> Are you using the latest drivers for the MIDI Interface? I think
> MIDI Interface - have you tired it with the MIDI Interface pluggedinto another USB port or
> bus?the AN1x and AN1xEdit
> USB MIDI Interfaces have a history of inadequate performance with
> - primarily due to the size of the SysEx dump the AN1x transmitsand the lack of any
> error checking in the USB protocol. Some work more reliably thanothers. You might have
> to experiment with your settings.Sequencer you try to
> Have you tried a simple SysEx bulk dump utility? If you have a MIDI
> use that. MIDIOX was a popular, stand alone utility amongst Windowsusers:
>utilities will allow you to
> http://www.midiox.com/
> Perhaps you might try a send and receive with MIDIOX. Some
> manually set the SysEx buffer size or the Receive timeout value.Yes im using the latest drivers, i have tried different ports, and im
> Jon
2008-02-26 by Jon
>That works too ;-)
> on the
> stuff
> pardon
> send
> make sound
> & Out cables are
> suggested.
> > bus?
> and the lack of any
> users:
> > Jon
> certain i have the lead connected absolutely fine.
> i think the simplest solution is just for me to save all my effects
> on pc, and only send them one way..
