An1x rack mount equivalent?
2008-02-03 by XOIO
Index last updated: 2026-04-02 23:10 UTC
2008-02-03 by XOIO
2008-02-03 by Desdinova
> Hi All,The closest you can get is the Kenton Plugstation filled with
> Am new here, however i USED to own an AN1X & thought it was fantastic.
> Had to sell due to a house move.
> I'm building up my studio again, but was wondering, What if anything
> has Yamaha brought out (past or present) that would qualify as a RACK
> MOUNTED version of the AN1x - i.e., a Virtual Analogue synth, with
> similar or better than An1x capabilities?
>Take care,
> Look forward to your answers
> Cheers
> Al
2008-02-03 by Bob S.
To: AN1x-list@yahoogroups.com
Sent: Sunday, February 03, 2008 4:44 AM
Subject: [AN1x] An1x rack mount equivalent?
Hi All,
Cheers
Al
2008-02-03 by Peter Korsten
> Am new here, however i USED to own an AN1X & thought it was fantastic.That's a bugger.
> I'm building up my studio again, but was wondering, What if anythingApparently, they did develop a rack-mounted AN1x (the AN1r), but it was
2008-02-03 by Jeff
> Message du 03/02/08 21:58[Non-text portions of this message have been removed]
> De : "Peter Korsten"
> A : AN1x-list@yahoogroups.com
> Copie à :
> Objet : Re: [AN1x] An1x rack mount equivalent?
> That's a bugger.
> cancelled just before commercial launch. Don't ask me why.
> Apart from the AN-200 and the PLG cards, the rack-mounted EX5R has
> limited AN capability (2 voice, or 1 voice if you put it in dual mode.
> It's also 3U high, just slightly shorter than it is wide (19"), and one
> beast of a synth. But it's stretching it a bit to count as what you're
> looking for.
> - Peter
2008-02-04 by Peter Korsten
> A guy of the list had tried to put an AN200 in a 19" rack. I think it's possible, the simplest way is to fix 2 "ears" on both sides of the case, but an issue may come with theA bigger problem would be that the thing isn't 19" wide. Just rack ears
> height of the AN200 which is probably not "standard".
2008-02-04 by Jeff
> Message du 04/02/08 08:06[Non-text portions of this message have been removed]
> Copie à :
> wouldn't be enough.
> - Peter
