re: presets
re: presets
2007-11-26 by spaceanimals
I liked the AN1X presets much better once I zeroed the eq settings. I
usually like to use an EQ to subtract not to add frequency and when you
boost the high end of a digital synth it's a bit of an icepick in the
ear effect.
Since it's a virtual synth, I find the most useful patches are the ones
that sound analogish but with a little extra--like morphing or
increasing the echo with the ribbon controller. Records well and fits
in a mix nicely. The EMU presets always sounded a little cold solo but
in a mix they really shine.
Rainbow Jimmy
Re: [AN1x] re: presets
2007-11-26 by Jeff
spaceanimals a \ufffdcrit :
>ear effect.
>Rainbow Jimmy
Let's speak electronics again (sorry...) !
You're right Jimmy: the old amps, effects and synths had a narrower
bandwidth than today's gear, not to mention that the frequency response
was often far from linear. Examples: spring reverbs, tube amps ...
A guy has found a simple but  probably efficient way to "analogize"
(sorry again for this horror!) his V.A. synth, by wiring _audio*_
insulation transformers between the output jacks and the PCB outputs.
See: http://www.retrosonik.com/DarkMods.htm
Because of the limited bandwidth of the transformers the harsh high
frequencies should be more or less cut down.The non- linearities in the
frequency range could cause some subtle resonances by increasing or
decreasing a bit some fixed frequencies.
I never tried this mod, but maybe i will...one day: i have the "big
brother" of his Red Sound synth, an AN1x and others... If there is
enough room left to put an audio transformer somewhere inside, why not ?
Last but not least: of course if you feel yourself unable to do this mod
cleanly, or if you cannot find the right transformers, don't do that! Or
ask a friendly electronics hobbyist to do it for you....
Don't want to have a full mailbox of "Shit, my synth is now out with
your fucking idea". First it is not exactly "mine" and now you know the
risks!!
Cheers
J.F.
*Obviously not supply transformers.... even small ones: it's like
putting water in your car tank !
2007-11-27 by audiomad99@aol.com
just to chime in ,....i use a pair of marinare lo1176a transformers that
have an gaped iron core with a rc network ( resistor capacitor network) for
taming  oscillation in higher frequencies,...and it gives a perceived  compressed
signal,....i never used it with my an1x but i used it  with my mixer which
has a 600 ohm  output balanced,.....and it sounded  almost like a nicecompressor
was on it ,.....i suppose the an1x is 600 ohm  too,......i have several
xformers to give different changes in  tone,....like vintage UFC, and Jensen
xformers ,...Jensens have a bigger bottom  ,...
In a message dated 11/26/2007 3:39:35 P.M. Pacific Standard Time,
jf.serviere@... writes:
See: _http://www.retrosonhttp://www.retrohtt_
(http://www.retrosonik.com/DarkMods.htm)
risks!!
Cheers
J.F.
*Obviously not supply transformers.*Obviously not supply transformers.
**************************************Check out AOL's list of 2007's hottest
products.
(http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001)
