AN200 VCO-Pitch with controller Keyboard
2007-08-30 by sam ricci jr
Stefan:
I struggled with that very same thing on the AN200.
The oscillator pitch can only by changed using a system exclusive string,
not a continuous controller or the edit matrix.  The knob or slider on your
controller must be able to store and transmit a string (F0 xxxxx F7).
You can put the string in a midi file or you can put  it in a sequencer
track and send it that way.
You would need 4 sysex command strings (2 for coarse pitch and 2 for fine
pitch).  I have them at work and I will post them for you when I get there.
Sam in NJ
> 1a. AN200 VCO-Pitch with controller Keyboard?
>     Posted by: "lordoid" blurr@... lordoid
>     Date: Mon Aug 27, 2007 6:24 am ((PDT))
> Hi!
> I want to control the VCO1 and VCO2 Pitch on my AN200 with a Midi
> Keyboard (Edirol
> PCR A30) because i don't want to use the Editor. Is there a way to do
> this?
> Thanx a lot!
> Stefan
Re: AN200 VCO-Pitch with controller Keyboard
2007-08-30 by samriccijr
Sysex Strings for VCO Semi and Fine Tune
Here are the sysex strings to change the octave, semitone and fine
tune of the AN200.  You can insert these into a sequencer track or
you can save them as midi files and play them into the AN200. You
have to check to see if your controller knob will transmit sysex
strings and you have to check the format of the bytes (decimal d or
hex h).
This assumes that the AN200 is set to channel 1
VCO1 SEMITONE
F0 4C 10 5C 10 10 18 mm F7
VCO2 SEMITONE
F0 4C 10 5C 10 10 21 mm F7
mm has continuous value
hex 00 to 7F (decimal 0-127)
nn has specific octave values
OCTAVE	HEX	DECIMAL
-5 oct h 04 d 4
-4 oct h 10 d 16
-3 oct h 1C d 28
-2 oct h 28 d 40
-1 oct h 34 d 52
 0 oct h 40 d 64 (middle c4)
+1 oct h 4C d 76
+2 oct h 58 d 88
+3 oct h 64 d 100
+4 oct h 70 d 112
+5 oct h 7C d 124
To set VCO1 to +1 octave above middle c, the sysex string in your
sequencer or midi file would be:
F0 4C 10 5C 10 10 18 4C F7
To set it back to 0 you would enter
F0 4C 10 5C 10 10 18 40 F7
Likewise to fine tune the VCOs the strings are
VCO1 FINE TUNE -50 to +50 cents
F0 4C 10 5C 10 10 19 nn F7
VCO2 FINE TUNE
F0 4C 10 5C 10 10 22 nn F7
nn has continuous value
hex 0D to 72 (decimal 14-114)
fine tune zero is hex 40 (decimal 64)
to fatten VCO1 and VCO2 - detune +/- 3 cents:
F0 4C 10 5C 10 10 19 43 F7
F0 4C 10 5C 10 10 22 3D F7
to reset them back to zero:
F0 4C 10 5C 10 10 19 40 F7
F0 4C 10 5C 10 10 22 40 F7
I could not find a way to assign semitone to the control matrix to a
controller.  If anyone has done this please post.  I hope this helps.
Good luck,
Sam in NJ
