Bought Used AN1x! Having Issues. Help!
2007-02-19 by erroneusnickname9876
I just bought a used AN1x. Got a good deal on it but having some issues. The scene lights
will not come on. I reset it to factory and it's still like that. I used to have a cs1x and was
under the impression that you just push the button to turn them on. Anyone else even have
this problem? Also, I'm looking to update the software. I see there's a physical chip available?
What does this do that a sysex update can't? Are they still for sale? Will it fix my scene
problem?
I can't find os updates ANYWHERE. Any ideas?
Thanks!
Re: [AN1x] Bought Used AN1x! Having Issues. Help!
2007-02-19 by Jeff
Hello !
>The scene lights will not come on.
Do you have other lazy LEDs on your synth ? No?
Go to a 2 scene patch like the factory "Great Morph"( nr 74) , move the
mod wheel and listen.... you must hear a progressive changing sound .
Then push only one "scene" button , you must hear only one of the
sounds, try the other one and finally push both buttons together . If
all is OK, you'll have to check the connectors inside the AN1X , unplug
and plug them carefully . Of course the connectors related to the
control panel . On the worst case you will have to change the LEDs but
it's rather strange that both fail at the same time....
Concerning the "scene" LEDs they are sometimes "flashing" when you play
but without any effect on sound or anything else.
>I used to have a cs1x and was under the impression that you just push the button to turn them on.
It's the same on AN1X. When you load a patch one or both "scene" LEDs
are lit depending on the patch. Pushing a "scene" button will enter in
"edit" mode (see on the display).
The software revision has nothing to do with the control panel and (as
far as i know) is still available as an EPROM by Yamaha customer service...
J.F.
erroneusnickname9876 a \ufffdcrit :
>problem?
>Thanks!
>avast! Antivirus: message Entrant propre.
>Base de donn\ufffdes des virus (VPS): 000714-4, 19/02/2007
>Test du: 19/02/2007 23:35:20
>avast! - copyright (c) 2000-2007 ALWIL Software.
>http://www.avast.com
avast! Antivirus: message Sortant propre.
Test du: 20/02/2007 00:49:21
2007-02-20 by jesse meyer
Actually, no matter what i do with the scene buttons,
they don't change the sound. It's not so much that
they don't light up. It's that they don't work. The
scene button does nothing, seperate or together. Also,
the "Seq/Edit Setup" row in the matrix shows the
parameters for the "utility Setup."
Very strange things to have broken...Any ideas?
--- Jeff <jf.serviere@...> wrote:
> Hello !
> changing sound .
> only one of the
> related to the
> change the LEDs but
> time....
> both "scene" LEDs
> J.F.
> >problem?
> >Thanks!
> 19/02/2007
> 19/02/2007
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121
Re: Bought Used AN1x! Having Issues. Help!
2007-02-20 by Jon
--- In AN1x-list@yahoogroups.com, "erroneusnickname9876"
> this problem?
Never heard of this issue, very odd. You are correct in that
selecting one Scene or the other in a Voice should activate that
Scene. Specifically: does the sound not change when selecting either
Scene 1 or 2, or is it simply the LEDs do not illuminate?
The default set-up for the the Factory Voices is such that pressing
both Scene buttons simultaneously would result in both LEDs
illuminating and the Mod Wheel can be used to morphed the two
scenes. Selecting either Scene 1 or 2 would allow you to toggle
between the two independently programmed layers within a Voice.
Have you inquired of the seller whether this was his experience too?
Was it working prior to the sale or did he not realize this was an
issue when your AN1x was placd up for sale? Perhpas you could return
it after making the seller aware of your issues.
I would suggest opening up your AN1x and checking whether any of the
internal ribbon cables connecting the keyboard and controllers to
the mainboard has come loose during transit - this is not an
uncommon issue for the AN1x.
chip available?
Yes, v1.04 is the most recent, and apparently final, OS update to
the AN1x. It was released some years ago. It is available as an
EEPROM that most skilled users can install without much difficulty.
> problem?
The AN1x is not equipped with the necessary FLASH ROM for a SysEx
update - this useful feature was introduced later models - the RM1x
and CS6x. The OS update will likely not correct the error you've
encountered with the Scene LEDs.
We've just had this very conversation on AN1x-list within the past
week - the details of which can be found in this thread:
http://launch.groups.yahoo.com/group/AN1x-list/message/10642
Jon
Re: Bought Used AN1x! Having Issues -- Diagnostics
2007-02-20 by pcbye111
> > this problem?
Greetings:  Two simple things to try.  First do a FULL factory reset.
Power off, hold down [7] [8] [9] and power on.  Select [9] for a full
factory reset.  Power off.  Power on.  It should boot up with RELAX
Co:001 with the Scene-1 and Assign buttons lit.
If not, power off.  Hold down [0] [-] [+] and power on.  Release the
three keys once the ROM Version is diplayed and you will go into
Diagnostics Mode.  If you want to run the full gamit, you will need a
MIDI Cable from the IN to the OUT.
Once in Diagnostics, you can scroll through them with the + - keys
and select one to run.  Press the Store Key to start one of the tests.
In particular, you want test #4 SW&LED.  Go to #4 with the Plus + key
and press Store.  Scene-2 Should be the first LED to light up.  Press
it, then Scene-1, press it.  It will then go the the Knobs.  Press
them. Then SYNC, VCO, etc, then the TEN Key Pad, the Rocker Switches,
then back to the Rotary Knobs, etc.
If you fail here, you most likely have a loose cable.  Open it up and
gently pull them all and reseat.  Be careful, they usually have a
locking tab on them -- I don't remember.
FYI:  If you ever want to know, or name your keys -- use a dry erase
marker for ease of removal.  The Keyboard Diagnostic gives you the
name of each key in sequence -- Ha! Ha!
It behooves everyone to at least run the Diagnostics once or twice to
get the hang of it and see if all is well.
Also, the ONLY upgrade is the V1.04 OTP EPROM available from Yamaha
in a previous post.  If Yamaha no longer has it, someone may be able
to burn one -- Only if no longer available though.  It is well worth
the $37.00 USD.  It fixes a lot of things -- A lot of things.
Best of luck;
Peter
2007-02-20 by Andrea TONI
emm sorry to ask but ...
if it fixes a lot of things
how come it is impossible to have a list of them ?
_IF_ it is legal i don't mind making copies of the ROM but i have only 1.03
cant we organize here a common update ?
Regards
--------------------------------------------------Env1-----Env2--Env3-----------
Andrea.TONI@...                          Vco1 \    |     |  \
Solar System Missions Sci-SM                      Vco2-->--Vcf-->Vca-->Ducati996
www.rssd.esa.int                                  Vco3 /    |     |  /
--------------------------------------------------Lfo1-----Lfo2--Lfo3-----------
Best of luck;
Peter
Re: [AN1x] Re: Bought Used AN1x! Having Issues -- Diagnostics
Thanks, I tried the diagnostic. The scene lights don't
turn on and the buttons don't respond to the keypress.
I tried the factory resest again and still nothing. I
suppose my next stop is surgery. Anything I should
know before I go poking around in there?
> but having some
> still like that.
> button to turn them
> > > this problem?
> FULL factory reset.
> boot up with RELAX
> on.  Release the
> will go into
> with the + - keys
> one of the tests.
> with the Plus + key
> light up.  Press
> Knobs.  Press
> Rocker Switches,
> usually have a
> use a dry erase
> gives you the
> once or twice to
> someone may be able
> It is well worth
> of things.
> Best of luck;
> Peter
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
http://autos.yahoo.com/green_center/
Long -- Soap Box -- Reply -- Sorry!
only 1.03
As far as the fix list goes, I am unaware of any fix lists published
by Yamaha on any of their gear.  I have no less than two of every,
what I consider "Good/Classic" Synths, Effects Processor, Rack Mixer,
etc, etc, Yamaha Made since the Early/Mid 80's.  Two Studios full.
Most have at least a 4th Generation ROM update in them if I recall.
Most I have no idea what they fixed.  Talking to Yamaha, they
frequently can't tell you either.  It is more evolution.  Quirks that
were reported in the field that most never new about or noticed and
were fixed in production or shortly there after.  For instance the
DX7II is at V1.09.  As far as I know, I am one of the few that have
that Rev.  Can't tell you exactly what it does.
My guess is many of the fixes are things found out about
interoperability with other gear after the fact -- not everything can
be tested.  MIDI issues, Timing, Sequencers, Disk Drives, etc, etc.
As an example, you have to realize, that when the DX7 was released,
the MIDI spec. wasn't even complete.  It got fixed in later ROM's.
The EX5/7 had a lot of issues.  SCSI, Disk and timing issues, but
lot's more I guess.  That's at 1.11 for the OS and 1.14 for the
Waves.  The A3K at V2.0 ROM, and the A4/5K at 1.50 Software.  The
AK's can be re-flashed by floppy disk -- nice.
In general, once you get enough gear out there, somebody will find
something that doesn't work correctly, and hopefully it get's fixed,
but not all users do the same thing or appear to have the same
problem.  It depends on what they are doing. We should all feel lucky
that Yamaha Actually does fix and support these things.  Where else
can you get a ROM upgrade for a 20+ year old synth.
On copying and distributing ROM code, etc.  I don't want to do it
unless Yamaha gives the OK.  My assumption is, they would allow it --
if you don't sell it.  You can freely down load the software flash
updates for A4/5k, Motif, etc, so the Code is not necessarily the
issue.  Their charge for ROM's -- if not free -- has to be close to
their cost.
It is a serious pain to handle the calls, inventory, burn, ship, etc,
etc. on something that they will never make another nickle on.  Other
vendors pretty much tell you to buy a new synth or what ever.  One
other thing.  I do burn my own ROM's, but once you go out and start
looking for the chips, they tend to be NA or pretty expensive.  The
last batch I got, and the one's I think may work on the AN I bought
used from Singapore and cost about $6.00 USD ea.  New from a vendor
or a chip broker $20.00 - $50.00+ USD -- if they even have one in
stock.  In the past, I sent clean chips to Yamaha and they burned
them for me free of charge.
Somebody, or I will one of these days -- I've been meaning to do it --
 is contact Yamaha -- I know the person who may help -- and ask for a
list of all the ROM Versions -- at least for my gear -- and see if I
could roll my own and "Free"ly redistribute them -- cost plus postage
of course.
BTW:  If someone has the AN Service Manual, maybe you could let us
know what the ROM is.  Like a M27C800 or a 8Mbit, or a 1Mbx8 or a
512kbx16 or some such thing...............  Either the parts list or
the block diagram would tell you.  The new chip from Yamaha is a OTP
imprinted with Yamaha stuff.
Hum!  Just for kicks -- I had an AN1x on the bench here with just a
couple of screws in the pan.  I pull the ROM and was successfull at
burning a copy on to a M27C800-100F1.  I plugged it in and it passed
the Diags. so I guess that is the chip.  Hard to find one too.
Discontinued in 2000 if I recall, but used in a lot of Yamaha gear up
through the EX and A3K anyway.
Well, that's my 2cents worth if it has any value.
Best regards;
Peter
Before you start, you may want to pick up a NEW CR2450 Battery and
replace it while your at it.
I've got one open now.  First off.  Get some damp bath towels to lay
the synth upside down on.  A quick and diry way to get one damp is to
throw a clean bath towel in the dryer and toss in a clean WET wash
cloth and tumble for a few minutes.
Work in bare feet on a wood floor -- no socks anyway.
Pull the volume knob stright up and off.  Lay the Synth down with the
back of the facing you, take the the two dozen or so screws on the
bottom and remove the cover.
The circuit board you are looking for will be on your far left close
to you.  Remove the four screws holding down and carfully wiggle it
up and out.  Put a hand under to push a little on the volume control
shaft.  Be carefull as the LED's need to come up out of their holes.
Flip it over.  There is one connector, and a punch down block.  It
looks like it is the punch down block where the connections could be
loose.  If things look OK, take a pen knife or use the BACK edge of a
razor knife and gently press the wires into the connector notches.
This may do it.  While your at it, go over all of the accessable
screws and give them a twist if loose.  Many are the ground rail for
the PC boards.
If that does not do it, those leads lead to a Relay Board under the
Main System board.  Wires could be loose there on a similar
connector, or there could be bad relays -- not too likely.  Still,
most likely a loose connector.  Getting under the system board is a
bigger job.  Go slowely and don't drop any tools on any thing.
Good Luck...............
Peter
2007-02-20 by Jeff
Hi Jesse !
2 possible things at this point :
one or more ribbon cables are disconnected inside, maybe during shipping ?
a dry solder joint on a connector ?
For the matrix check if there is no "extra position" outside the normal
rows .... In this case the left rotary switch has been removed and badly
replaced.
All these things suggest me that the previous owner has tried to repair
something inside and has forgotten to check carefully at the connectors
and selector positions before removing, or forgotten to re-plug a cable
..... But i think it is not a fatal issue, only a matter of bad(s)
contact(s) or wrong wiring somewhere, the most common plagues in
electronics.
Cheers
J.F.
jesse meyer a \ufffdcrit :
>>Hello !
>>changing sound .
>>only one of the
>>related to the
>>change the LEDs but
>>time....
>>both "scene" LEDs
>>J.F.
>>>problem?
>>>Thanks!
>>19/02/2007
>>19/02/2007
>Be a PS3 game guru.
>Test du: 20/02/2007 23:22:10
Test du: 21/02/2007 00:02:44
2007-02-21 by Jeff
Good idea if there is no risk of lawsuit .... I can do that too, but i
don't remember what is my own synth software revision...
If it is possible the better would be to put the EPROM content on the
website in a JEDEC or binary file format, very small and usable by most
of the EPROMs hardware programmers. And not to forget to specify the
right blank EPROM reference (access time included)  : the size and the
number of pins could not be sufficient .
J.F.
Andrea TONI a \ufffdcrit :
>Regards
>Best of luck;
>Peter
>Community email addresses:
>  Post message: AN1x-list@yahoogroups.com
>  Subscribe:    AN1x-list-subscribe@yahoogroups.com
>  Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>  List owner:   AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
>   http://groups.yahoo.com/group/AN1x-list
>The AN1x Control Synthesizer FAQ::
>  http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
>Yahoo! Groups Links
>Test du: 20/02/2007 23:22:53
Base de donn\ufffdes des virus (VPS): 000715-0, 20/02/2007
Test du: 21/02/2007 02:08:22
2007-02-21 by jesse meyer
Thanks for the info. I took her apart. I removed that
board and tried to push the wires back in. The ones to
the volume connector moved in more, but the connector
for the scene buttons are in metal teeth, and aren't
able to be pushed in. Besides, they look pretty good.
Still no luck. She's still open if anyone has any more
suggestions.
> don't
> keypress.
> nothing. I
> CR2450 Battery and
> bath towels to lay
> get one damp is to
> clean WET wash
> anyway.
> Synth down with the
> screws on the
> your far left close
> carfully wiggle it
> the volume control
> of their holes.
> down block.  It
> the BACK edge of a
> connector notches.
> the accessable
> ground rail for
> the PC boards.
> Board under the
> similar
> likely.  Still,
> system board is a
> any thing.
> Peter
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/
2007-02-21 by Ed Edwards
As a tech, this can't be preached enough:
Unseat, unplug and disconnect everything possible - clean them - then
reconnect and test.  Don't just jiggle or wiggle.  Heat, corrosion and
vibration can cause a lot of strange things to happen over the years.
If this doesn't work, then it's time to tap... but first visually
inspect for bad solder joints.  Then take the eraser end of a pencil and
tap all over the board while you have it powered up to see if anything
happens.  This is a technique of finding bad solder connections.
It's unusual for a small section of an EPROM to fail and cause symptoms
like yours.  It's usually all or nothing, therefore I'm suspicious of a
connection being compromised somewhere.
As far as copying chips is concerned:
Yamaha is no longer making any money on this unit which they obsoleted
years ago.  Making copies to repair or restore existing units is like a
machinist making copies of parts of old cars when the factory no longer
supplies them.
*Ed Edwards*
http://www.ezekielswheel.com
http://www.untiedmusic.com/ezekiel
http://mysite.verizon.net/vze29bq6
> suggestions.
>> don't
>> keypress.
>> nothing. I
>> CR2450 Battery and
>> bath towels to lay
>> get one damp is to
>> clean WET wash
>> anyway.
>> Synth down with the
>> screws on the
>> your far left close
>> carfully wiggle it
>> the volume control
>> of their holes.
>> down block.  It
>> the BACK edge of a
>> connector notches.
>> the accessable
>> ground rail for
>> the PC boards.
>> Board under the
>> similar
>> likely.  Still,
>> system board is a
>> any thing.
>> Peter
2007-02-21 by Jon
--- In AN1x-list@yahoogroups.com, jesse meyer
> suggestions.
Replace the battery as suggested in this thread...I think Pete posted
the model type and number.
Jon
Re: AN1x Diagnostics
2007-02-22 by jesse meyer
I replaced the battery and did a full reset. Still no
help with the scene buttons/matrix row selection. I
also tried pressing the solder joints, they all seemed
ok. I checked all ribbons and wires I could find with
the same results. Any more ideas?
The diagnostics runs fine except for when it says
'scene' because obviously, the button isn't
responding. At that point I have to power down.
Any suggestions on how to find a reasonable repair
facility? Will Yamaha service this? I'm near Chicago
if that helps. Any idea what I can expect to pay? Any
idea what could be causing this sort of problem?
I haphazardly bought this knowing full well that it
wasn't responding like it should but my want
overwhelmed my logic. I spent $200 on it, which is I
suppose what they cost fully functioning. I'm
typically very good at getting deals. This time, I was
on the wrong end.
I bet I could sell it broken for $150 and buy another
one for $250 and end up loosing $100 on my original
purchase. That being said, I don't want to spend more
than $100 on repairs.
Thanks everybody, you've all been really kind and
helpful.
-jesse
Now that's room service!  Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
http://farechase.yahoo.com/promo-generic-14795097
2007-02-22 by Jon
--- In AN1x-list@yahoogroups.com, jesse meyer <erroneusnickname9876@...> wrote:
Here's the Yamaha Corp USA Service and Support web site:
http://tinyurl.com/y6hodb
I don't doubt that they would be able to service your AN1x.
> on the wrong end.
$200?!? That's cheap, I assumed they were still selling $300-350 2nd hand.
If it were my board, I'd have it serviced. Depends on which is more important to you - the
time and effort spent reselling and purchasing another AN1x (and maybe starting from
scratch with different issues), or the time and effort spent working with Yamaha Service &
Support. FWIW, I found Yamaha very agreeable to deal with.
Good luck.
Jon
2007-02-22 by pcbye111
Jesse:
Step-1.  Go to the Yamaha Site and do a lookup on Yamaha Service
Centers in your area.  Frequently, you can find some old guy that
runs a shop out of his house and won't bleed you to death.  He will
fix it and be happy to help.
Step-2.  If that fails, I will (try and) repair it for you.  You pay
postage both ways - that could cost up to $100.00 round trip to
Minnesota.
Step-3.  I'll buy it from you for $150.00 plus postage and you can
giver er another go.  If I can't ultimately fix it, it becomes parts
for folks here in the group.
Let me know.
Peter
> on the wrong end.
> helpful.
> -jesse
______________
Re: [AN1x] Re: AN1x Diagnostics
I've been in contact with Yamaha and they are going to
try and recommend someone local. I looked the area up
in the listings and wasn't able to get ahold of anyone
so far myself.
I was tempted to just take a loss on this synth. I
hadn't even played it really because I've been
spending so much time trying to figure out what's
wrong with it. Well, I put it back together and
started editing a few patches. Now I know why after 10
years there's still an active user group for this
synth. It's quite expressive. I loved my old cs1x when
I was a teen for pads, but this is amazing. I have a
broken, but usable alesis ION(which I've had an
incredible amount of trouble with), and am trying to
decide which to fix, which to sell, and which to
keep...
The Ion is a very capable synth, but I'm afraid many
corners were cut in production. I've had the main
outputs die on 3 separate units, ghost knobs, broken
keys, etc.
The reason I'm unsure I want the An1x is when
something is altering the sound and I want to change
it, it's hard for me to find. I suppose I'll get the
hang of the matrix again? I'm used to one knob/one
function, or at least one knob/one menu.
In response to the offer on fixing/buying the AN1x
from me, I will say this: I very well may be
interested in one of those options, and I thank you
for them. I do, however, need to spend some time with
this synth and decide if I want to keep it around.
I'll also wait for yamaha to get back to me about
repair options.
Thanks again for all the help. Hopefully I'll fall for
this synth and get her up and running again soon.
The fish are biting.
Get more visitors on your site using Yahoo! Search Marketing.
http://searchmarketing.yahoo.com/arp/sponsoredsearch_v2.php
2007-02-22 by Dale
on my third ION too but
the first batches had bad pots as they call them
I manage to get the first 2 like that ...
third one, the one I have now, some problems but over all useful
AN200 and DX200, no an1x here.. I had a chance to get one but
decided on the JP8000 at the time. ;-)
now I added FM7, Reaktor and a PEK ..
dale
band web pages
Inquisitor Betrayer
New CD "Space Elevator" Get it at http://cdbaby.com/cd/inquisitorbetrayer
http://www.inquisitorbetrayer.com ,
http://www.myspace.com/inquisitorbetrayer ,
http://www.musicforte.com/member/ib_staff and
Angel's Wings http://www.soundclick.com/angelswings
iTunes
http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewAlbum?playListId=200365877
Podcast
http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=204307934
New group for Jerome Froese Jerome_Froese@yahoogroups.com 16 year member of
Tangerine Dream
<snip> I have a
keep...
keys, etc.
<snip>
2007-02-23 by Jeff
Hello Jesse !
i think they are right . If you cannot repair it by yourself, try to
have it serviced .... This synth is becoming more expensive each year on
Ebay . Not in France but in such case the shipping costs could be more
expensive than your repair, not to mention possible issues with the
customs. From my point of view this is only a minor failure. Did you try
to get some refund from the seller ? I think you could if he or she has
not mentioned "sold as it for parts" or "needs servicing"....
J.F.
pcbye111 a \ufffdcrit :
>Jesse:
>Minnesota.
>Let me know.
>Peter
>>on the wrong end.
>>helpful.
>>-jesse
>______________
>Base de donn\ufffdes des virus (VPS): 000716-0, 22/02/2007
>Test du: 22/02/2007 21:13:07
Base de donn\ufffdes des virus (VPS): 000716-1, 22/02/2007
Test du: 23/02/2007 01:21:30
2007-02-23 by jesse meyer
I didn't ask for a refund for several reasons, but the
most important is that I simply may not even want one.
For $200 the only things not working are the
scenes(which I really DO want) and the sequencer row
in the matrix which, being a logic user, I don't care
about. I will continue to make patches until I make a
clear decision on it.
I figure its resale value is comparable to what I paid
and I'm hopefull about repair costs.
> Hello Jesse !
> yourself, try to
> costs could be more
> issues with the
> servicing"....
> J.F.
> >Jesse:
> Yamaha Service
> some old guy that
> death.  He will
> for you.  You pay
> round trip to
> >Minnesota.
> postage and you can
> it becomes parts
> >Let me know.
> >Peter
> no
> I
> seemed
> with
> Chicago
> Any
> it
> I
> was
> >>on the wrong end.
> another
> original
> more
> >>helpful.
> >>-jesse
> >______________
> hotels
> your fit.
> 22/02/2007
> 22/02/2007
Cheap talk?
Check out Yahoo! Messenger's low PC-to-Phone call rates.
http://voice.yahoo.com
Re: 3rd Ion
Have you dealt with Alesis' tech support? They've
never even replied to me. Where did you get your ions
serviced? What was the cost?
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains.
2007-02-23 by Bob S.
If you can isolate it to a part, Yamaha still stocks some parts for the AN1x.  I recently purchased a few AN1x keys at a few dollars apiece from them....
Bob
El Segundo, CA
  To: AN1x-list@yahoogroups.com
  Sent: Thursday, February 22, 2007 6:54 PM
  Subject: Re: [AN1x] Re: AN1x Diagnostics
  > Hello Jesse !
  > yourself, try to
  > costs could be more
  > issues with the
  > servicing"....
  > J.F.
  > pcbye111 a écrit :
  > >Jesse:
  > Yamaha Service
  > some old guy that
  > death. He will
  > for you. You pay
  > round trip to
  > >Minnesota.
  > postage and you can
  > it becomes parts
  > >Let me know.
  > >Peter
  > no
  > I
  > seemed
  > with
  > Chicago
  > Any
  > it
  > I
  > was
  > >>on the wrong end.
  > another
  > original
  > more
  > >>helpful.
  > >>-jesse
  > >______________
  > hotels
  > your fit.
  > >Base de donnÚes des virus (VPS): 000716-0,
  > 22/02/2007
  > Base de donnÚes des virus (VPS): 000716-1,
  > 22/02/2007
  Cheap talk?
A new update with my issues. I tried out the AN1x
logic environment(I'm in osx and can't use the
an1xedit.) When I change from Scene 1 to Scene 2 in
logic, nothing changes on the AN1x, but if I select
Scene 1+2, the modulation wheel now morphs between the
2 scenes. The buttons still don't respond, and the
lights are still out, but at least the morph is
working. Since the buttons don't respond, I still
can't save scenes, but it makes me think it's at least
a little less broken.
Any idea why switching from Scene 1 to 2 doesn't
change the sound but activating Scene 1+2 does?
Does any of this spark new ideas? Thanks!
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
2007-02-23 by Jon
> an1xedit.)
If you have Panther, or Tiger, on your PowerPC Mac - and you run Classic - then you can
run AN1xEdit w/ OMS alongside a USB MIDI Interface that has an OMS USB MIDI Driver
under Classic and it works perfectly well.
That makes no sense because Scene Select is simply sending the AN1x MIDI CC #003
while the AN1x is in Mode 2. I assume you're using AN1x Env.lso? The Scene Select from 1
-> 2 is simply sending the AN1x a MIDI CC of #003 with a value greater than '42' and
from 2 -> 1+2 is MIDI CC #003 with a value greater than '85'.
Have you tried to tweak Voice when select Scene 2 from the Logic environment? You
should be able to distinguish a difference from Scene 1.
Jon
Re: [AN1x] Re: 3rd Ion
2007-02-23 by Jeff
Never....
When i bought my AN1X i had the opportunity to buy either the Yamaha
synth or  an Alesis Ion or an Oberheim OB12 . The 3rd is said to be fine
sounding but unreliable , now i know the Ion is the same :-P  And they
were much expensive ....
Cheers !
J.F.
>Test du: 23/02/2007 08:19:42
Test du: 23/02/2007 08:29:43
