Re: [AN1x] Faulty black key
2006-09-24 by Bob S.
Don't know your answer for a single key not working except for the key/contacts itself but....
I need to take out my keyboard section apart to replace 3 broken keys....which screws on the keyboard assembly do the minimum for key removal or did you just unscrew away until it all came apart?
Bob
El Segundo, CA
To: AN1x-list@yahoogroups.com
Sent: Sunday, September 24, 2006 3:14 AM
Subject: [AN1x] Faulty black key
I have a black key on my AN1x keyboard which does not work (B minor I
think - I'm a guitarist so forgive me!, every other key works
perfectly. I have taken the keyboard aprat and everything looks fine,
rubber carbon contacts and pressure pads all fine - what could be
causing this?
2006-09-27 by Bob S.
Yes. Velocity & aftertouch.
Bob
El Segundo, CA
>From: brock <mtbis1@...>
>Sent: Sep 27, 2006 12:12 PM
>Subject: Re: [AN1x] Faulty black key
>I'm wondering if there is something else faulty, when
>I press a key should I hear several steps in volume?
>I.E. is the keyboard velocity sensitive? At the moment
>I it doesn't make any difference how hard a press the
>keys, the volume is 1 step - the exception being the 1
>faulty key, which has no sound at all!
>Also, does it have aftertouch?
>I'm thinking maybe a IC has gone or something.
>__________________________________________________
>Do You Yahoo!?
>Tired of spam? Yahoo! Mail has the best spam protection around
>http://mail.yahoo.com
2006-09-27 by brock
Un-screw all the screws on the external base.
The panel then comes away quite easily.
Now you will see inside your AN1X -there is a little
PCB just of the long PCB with the keyboard contacts,
undo the 4 screws for this PCB, but leave wires
attached, unplug 3 wire cable labelled 'AFT'. Now you
can access fully the keyboard PCB, carefully unplug
the ribbon connector from the long keyboard PCB- you
have to pull up the little locking pins on the side of
the socket, don't just try and pull the ribbon cable
straight out. Now undo all the screws for the keyboard
contact PCB - there are alot.
There is a plastic membrane which covers the rubber
contact strip, key are underneath.
It's all pretty obvious when you can see it all.
I have checked the contacts and they look perfect.
Do You Yahoo!?
Thank you Brock for that.....I have been waiting for this reply before I proceeded with disassembly....now I can take MY AN1x keyboard out to replace the keys.......I'll let you know how it goes......
Bob
El Segundo, CA
Sent: Wednesday, September 27, 2006 3:05 PM
Do You Yahoo!?
