Re: [AN1x] Re: My AN1x arrived & I need replacement keys
2006-09-16 by Bob S.
Thank you for the link...that Yamaha parts center is in the Los Angeles area right relatively near where I am located......
Bob
El Segundo, CA
  To: AN1x-list@yahoogroups.com
  Sent: Saturday, September 16, 2006 1:00 PM
  Subject: [AN1x] Re: My AN1x arrived & I need replacement keys
  --- In AN1x-list@yahoogroups.com, "bob_at_work_2000" <tttsystems@...> wrote:
  > Hello my new associates! My 1st AN1x arrived by international UPS
  > and guess what, it was damaged due to bad packing......So does anyone
  > have a source for replacement keys....I will need at least 3 of them.
  > I have not powered the unit or inspected it closely yet, so I don't
  > know what else I will need.....
  > Thanks
  > Bob
  > El Segundo, CA
  Bummer.
  Try here for parts replacement:
  http://tinyurl.com/zupcz
  The full URL is to cut & paste into your browser is:
  http://www.yamaha.com/yamahavgn/CDA/ContentDetail/Text_WithCatMenu_SC/
  0,,CTID%253D410040%2526CNTYP%253D,00.html#opt3
  UPSssss...bleeeeehhh :-/ Was there any insurance on the unit?
  Jon
2006-10-20 by Bob S.
..........entered in and prayed and laid his hands on him, and healed him.........
I fixed it all !
I found replacement keys in-stock at the Yamaha parts center near Los Angeles (less than $7 each, just remember to keep the metal spring piece inside the key as it does not come with the replacement keys) and did the job.  It was a little tricky to remove a key (had to do 3) and replace it but once you understand the technique, it's easy.  Also adjusted the sensitivity of the Aftertouch (there are two trim-pots inside, one for gain & one for offset).............My An1x is fully repaired and works perfectly......
Bob
El Segundo, CA
  Sent: Saturday, September 16, 2006 2:15 PM
  Subject: Re: [AN1x] Re: My AN1x arrived & I need replacement keys
  Bob
  El Segundo, CA
  > Thanks
  > Bob
  > El Segundo, CA
  Bummer.
  Jon
2006-10-20 by Jon
> I fixed it all !
> Bob
> El Segundo, CA
Congrats on the repair, gld it worked out for you,
The Aftertouch sensitivity of the AN1x has been an issue for many users. Could you
provide more details on how you adjusted it?
Jon
2006-10-20 by Jeff
Congratulations Bob !
Cheers.
J.F.
Bob S. a \ufffdcrit :
>I fixed it all !
>I found replacement keys in-stock at the Yamaha parts center near Los Angeles (less than $7 each, just remember to keep the metal spring piece inside the key as it does not come with the replacement keys) and did the job.  It was a little tricky to remove a key (had to do 3) and replace it but once you understand the technique, it's easy.  Also adjusted the sensitivity of the Aftertouch (there are two trim-pots inside, one for gain & one for offset).............My An1x is fully repaired and works perfectly........
>Bob
>El Segundo, CA
>  ----- Original Message -----
>  From: Bob S.
>  Bob
>  El Segundo, CA
>  From: Jon
>  > Thanks
>  > Bob
>  > El Segundo, CA
>  Bummer.
>  Jon
>  [Non-text portions of this message have been removed]
>Community email addresses:
>  Post message: AN1x-list@yahoogroups.com
>  Subscribe:    AN1x-list-subscribe@yahoogroups.com
>  Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>  List owner:   AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
>   http://groups.yahoo.com/group/AN1x-list
>The AN1x Control Synthesizer FAQ::
>  http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
>Yahoo! Groups Links
>Orange vous informe que cet  e-mail a ete controle par l'anti-virus mail.
>Aucun virus connu a ce jour par nos services n'a ete detecte.
>avast! Antivirus: message Entrant propre.
>Base de donn\ufffdes des virus (VPS): 0642-5, 20/10/2006
>Test du: 20/10/2006 23:58:59
>avast! - copyright (c) 2000-2006 ALWIL Software.
>http://www.avast.com
avast! Antivirus: message Sortant propre.
Test du: 21/10/2006 00:51:22
2006-10-21 by Bob S.
Thanks you all for the congrats.
When I get some time, I will document how to adjust/readjust the aftertouch sensitivity of AN1x...
Bob
El Segundo, CA
  Sent: Friday, October 20, 2006 3:51 PM
  Cheers.
  J.F.
  >I fixed it all !
  >Bob
  >El Segundo, CA
  > From: Bob S.
  > Bob
  > El Segundo, CA
  > From: Jon
  > > Thanks
  > > Bob
  > > El Segundo, CA
  > Bummer.
  > Jon
  >Yahoo! Groups Links
  >Base de donnÚes des virus (VPS): 0642-5, 20/10/2006
2006-10-21 by Jon
> Bob
> El Segundo, CA
Thank you - looking forward to it.
Jon
