[Fwd: Re: [AN1x] Re: Using a foot for scene switching?]
2006-09-14 by Jeff
I forgot one thing, very important :
if you don't find a Yamaha footswitch for your synth and you buy an
unbranded one be careful to choose an "universal" model where the switch
is either "normally open" or "normally closed" . Only one of these
configurations will work . I don't know which one , and this pedal could
be used with other instruments too.
J.F.
-------- Message original --------
Sujet: 	Re: [AN1x] Re: Using a foot for scene switching?
Date: 	Thu, 14 Sep 2006 19:18:24 +0200
De: 	Jeff <jf.serviere@...>
R\ufffdpondre \ufffd: 	jf.serviere@...
Pour: 	AN1x-list@yahoogroups.com
R\ufffdf\ufffdrences: 	<eebtf3+ctgh@...>
>I'm using an "on/off" switch, maybe a temporary one (sustain pedal
>type) will do the trick?
YES ! OF COURSE ! Because the hardware inside your synth is "waiting
for" an edge (transition between the "1" and "0" state or the opposite)
, not a logic level (1 or 0) to toggle between the 2 scenes . Take a
look at all the buttons on the front panel : they are all momentary
switches .
J.F.
lou.kadassy a \ufffdcrit :
>--- In AN1x-list@yahoogroups.com, "Jon" <jondl_2000@...> wrote:
>>--- In AN1x-list@yahoogroups.com, "lou.kadassy" <lou.kadassy@> wrote:
>>>I thought it would be easy to use a footswitch to, ahem, "switch"
>>>between scenes, but I haven't been able to do that.
>>>My question is: can I use a foot switch (or continuous foot
>>>controller, aka volume pedal) to switch between scene 1/2? I don't
>>>want to morph, I just need to switch.
>>>Any help would be appreciated.
>>>Lou
>>Yes, to both.
>>On the AN1x, set the [EDIT ROTARY] Knob to the UTILITY/SETUP menu.
>>Press Ctrl Device until you see FS displayed.
>>Press Ctrl No to change the value to 3: SceneSel
>>Press Ctrl Device until you see SCENE displayed, the Ctrl No value
>should also be 3:
>>SceneSel. If it's not, press Ctrl No to change the value to 3: SceneSel.
>>Play your sound, presee the Foot Switch (FS) to hear the 2nd Scene,
>release to hear the 1st
>>Scene. There is no Morphing invoked when using FS.
>>Repeat the above procedure for using a Foot Controller (FC).
>Obviously, Morphing can be
>>used with FC and you can have both FS and FC available
>simultaneously. Might get
>>confusing if you use the AN1x as a Master Control Keyboard ;-)
>>Hope this helps.
>>Regards,
>>Jon
>Jon,
>many thanks for your response.
>Unfortunately, it doesn't work as I expected. Did all the steps but
>when I press the switch *both* scene lights go on and I listen to a
>mix between the two.
>Thanks again,
>Lou
>Community email addresses:
>  Post message: AN1x-list@yahoogroups.com
>  Subscribe:    AN1x-list-subscribe@yahoogroups.com
>  Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>  List owner:   AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
>   http://groups.yahoo.com/group/AN1x-list
>The AN1x Control Synthesizer FAQ::
>  http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
>Yahoo! Groups Links
>Orange vous informe que cet  e-mail a ete controle par l'anti-virus mail.
>Aucun virus connu a ce jour par nos services n'a ete detecte.
>avast! Antivirus: message Entrant propre.
>Base de donn\ufffdes des virus (VPS): 0637-1, 13/09/2006
>Test du: 14/09/2006 18:08:19
>avast! - copyright (c) 2000-2006 ALWIL Software.
>http://www.avast.com
avast! Antivirus: message Sortant propre.
Test du: 14/09/2006 19:25:37
