Hi Bob,
I don't turn any knobs or buttons, the problem happens when I switch
on the AN1x after a few hours. When I switch the synth on, the edit
indicator instantly appears and thats when the VCF cutoff goes all
crazy.
Arthur
--- In AN1x-list@yahoogroups.com, "Bob S." <tttsystems@...> wrote:
> Doe this occur only when you turn the control/data encoder to a
new position? If so, then the encoder just need to be cleaned or
replaced......all my later Yamaha synth gear have encoder issues
when they get dirty as they are not sealed controls....
> Bob
> El Segundo, CA
> -----Original Message-----
> >From: Arthur Alexander Crichton <ac010b4919@...>
> >Sent: Sep 11, 2006 6:22 PM
> >To: AN1x-list@yahoogroups.com
> >Subject: Re: [AN1x] Another problem with AN1x
> >I am beginning to wonder if the problem is due to a bug in my
AN1x
> >as its very tempremental - one minute the sounds are ok with the
VCF
> >cutoff behaving itself and then the next minute they are sounding
> >strange with the VCF cutoff going back to value 97 when I try to
> >turn it to value 0 and so on.
> >Arthur
> >--- In AN1x-list@yahoogroups.com, "Jon" <jondl_2000@> wrote:
> >> --- In AN1x-list@yahoogroups.com, "Arthur Alexander Crichton"
> ><ac010b4919@>
> >> wrote:
> >> > Thanks for all of the replies but I have noticed that when I
do
> >an
> >> > entire factory reset and load the original sounds the problem
is
> >> > solved until I load in the sounds from AN1xEdit again where I
> >get
> >> > the problem again with the VCF cutoff behaving very strangly.
> >> > I wonder if its the sounds that I am sending from AN1xEdit to
my
> >> > AN1x which is causing the problem with the VCF cutoff?
> >> Which bank of user Voices are you loading into the AN1x? And
did
> >ou download the bank
> >> from the Files section for AN1x-list here at Yahoo! GRoups or
> >elsewhere?
> >> > Another thing I have found out is that I created a sweep
sound
> >on
> >> > the AN1x and saved it to AN1xEdit on my computer. When I go
to
> >load
> >> > that sound back to my AN1x from the computer it doesn't sound
> >like
> >> > it should because the VCF cutoff goes crazy.
> >> Why don't you load an example in .AN1 formate into the Voices
> >directory of the Files
> >> section so we can see what
> >> s up?
> >> http://launch.groups.yahoo.com/group/AN1x-list/files
> >> Jon
