Index last updated: 2026-04-03 01:03 UTC
AN1x Voice Problem
AN1x Voice Problem
2006-08-14 by Silent Android
I turned on my AN1x last night and for some reason all the D and Ab
keys wouldn't sound. Eventually I whacked the thing around and kept
hitting the keys hard and they came back.
I'm thinking there's some chip or connection that's loose inside the
AN1x that's causing this. Does anyone know where I can find it? Thanks.
Re: [AN1x] AN1x Voice Problem
2006-08-15 by Ed Edwards
You need to disable the Punk setting.
Otherwise, it won't play without slapping it around with extreme
vibration.  Lots of screaming in the microphone helps.
*sorry* couldn't resist
.... or, you could take off the back and make sure all chips and
connectors are making good contact.  There's no specific place to look.
Just re-seat all of them to be safe.  Corrosion is a common malady.
*Ed Edwards*
http://www.ezekielswheel.com
http://www.untiedmusic.com/ezekiel
http://mysite.verizon.net/vze29bq6
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
> The AN1x Control Synthesizer FAQ::
>   http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
2006-08-15 by Summa
Tried to remote control the synth via midi, might be only the
keyboard connection, since everything else is DSP based, so other
than on old analog synths, that have seperate chips/circuits for
every voice, soundgeneration on DSP based synths hardly fails for
only some keys...
CZ/VZ 		mailing list	: http://groups.yahoo.com/group/CZsynth
FMHeaven	mailing list	: http://groups.yahoo.com/group/fmheaven/
FS1R 		mailing list	: http://www.ampfea.org/mailman/listinfo/fss-list
Vokator		mailing list	: http://groups.yahoo.com/group/vokator
Wellenform Chat  So and Do 22.00 CET: http://chat.moogulator.com/
Who said what - why where were you when this thread appeared?
Are you the original author, Summa or another whose arphoured
entitlement sent the aouphier's appliances' to distraced curved tracings
lacking previously colored attractiveness?
*Ed Edwards*
> only some keys...
>> Yahoo! Groups Links
2006-08-15 by Summa
Nope I'm not the original author of that thread, but my typo "tried =
try" might let you think otherwise ... so my advice was to try
another keyboard to remote control the synth via midi, to check if
it's a keyboard problem. I wasn't refering to your answer...
Sorry, I don't completely understand the last part of your sentence,
probably since english isn't my native language, but I sure wanted to
help...
...Summa
Re: AN1x Voice Problem
2006-08-16 by Jon
Ed is right, open up your AN1x case and check the ribbon cable connections to the main
board are all fastened tightly - this problem has been reported on AN1x-list on more than
one occasion. The same trouble has been known to affect the Ribbon Controler too. Good
luck.
Jon
2006-08-16 by Silent Android
Thanks, but the ribbon cable works fine.
I found the cuprit though. I had the bottom off and held down a dead
note on a sustaining patch. When I wiggled the keyboard ribbon
connector header on to the small keyboard control board (the small
3x4" circuit board next to the mainboard)the note came back. It
appears that the solder joints to one of the connectors header is
loose; I can wiggle it more freely than the other one. Oh well, as I
type this I have a solder iron heating up! :)
Thanks all.
Elson
Thanks.
Controler too. Good
> luck.
> Jon
Re: [AN1x] Re: AN1x Voice Problem
2006-08-16 by Ed Edwards
Today's lesson - engineering terminology.
"Selective Vibration Adjustment"  -- bang it with your hand on it's side
until the problem clears up.
Quiz on Friday.
*Ed Edwards*
> Thanks all.
> Elson
> Thanks.
> Controler too. Good
>> luck.
>> Jon
