Index last updated: 2026-04-03 20:49 UTC
OT off topic - Contact cleaner
2006-08-02 by Martin Phillips
Hello, I'm posting this question on this forum, rather than any of the other synth lists I
subscribe to, simply because it strikes me as the "nicest", most helpful one of the lot.
So apologies if this is of no interest to you, though I think that as we are all gearheads your
answers might be helpful to quite a few people.
I just bought some contact cleaner, in a spray can ("Servisol Super 10 switch-cleaning
lubricant"), because a lot of my gear has got dusty up in the attic, particularly my mixing
desk, one channel of which seems to have stopped working altogether. I'm hoping I can get it
working again by opening it up and giving it a good spray, but I've never used this stuff
before. My question is: is there anything in particular I should look out for, or avoid, when
spraying this stuff? Is it really safe just to blast away and try to clear out any grime and dust?
And, er, to try to make it a bit more on-topic, would the innards (and, er, outards) of the
AN1x benefit from this stuff at all? Or maybe just the connectors at the back, i.e. the
analogue bits?
Can I be trigger-happy with my spray can?
Martin
Re: OT off topic - Contact cleaner
2006-08-02 by martymart2
Wow, Martin, you have cool name.  This Martin Philip responding!
I would be pretty judicious with that cleaner.  It is not likely meant
to clean outside surfaces, and since it is a lubricant, will leave a
residue.
Also, you don't want the cleaner to get all over the circuit boards
and electronic components.  You could create shorts and damage your
AN.  You wouldn't want that, now!
Try to isolate the spray directly in or on switches, pots and/or
jacks.  A light application is usually better that a heavy one.  Just
repeat the light application if the first time around didn't clean the
connection.
Martin Philip (aka martymart2)
--- In AN1x-list@yahoogroups.com, "Martin Phillips" <babelcordoba@...>
10 switch-cleaning
the back, i.e. the
> analogue bits?
> Thanks,
> Martin
Re: [AN1x] OT off topic - Contact cleaner
2006-08-06 by Jeff
I don't have any experience of  "Servisol Super 10 switch-cleaning
lubricant" (i use "KF contact cleaner") but don't forget 2 things :
1) these "switch cleaners" are dedicated to ... contact cleaning ,
including pots, knobs, keyboards contacts ... , not to clean the front
panel of  your gear . They are often greasy , because they are a mixture
of a solvent (to clean) and a lubricant (to prevent a further oxydation) .
2)you have to spray only the contact parts and move them quickly just
after to wipe out the dust, rust or anything of this kind inside and
allow the lubricant to flow everywhere it is useful.
You can clean the front panels and keys with foam sprays used to clean
the computers . Don't put this stuff in any contact , specially with
water based foams !
J.F.
Martin Phillips a \ufffdcrit :
>analogue bits?
>Thanks,
>Martin
>Community email addresses:
>  Post message: AN1x-list@yahoogroups.com
>  Subscribe:    AN1x-list-subscribe@yahoogroups.com
>  Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>  List owner:   AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
>   http://groups.yahoo.com/group/AN1x-list
>The AN1x Control Synthesizer FAQ::
>  http://www.geocities.com/jondl_2000/an1x_faq/an1x_faq_toc.htm
>Yahoo! Groups Links
>Orange vous informe que cet  e-mail a ete controle par l'anti-virus mail.
>Aucun virus connu a ce jour par nos services n'a ete detecte.
>avast! Antivirus: message Entrant propre.
>Base de donn\ufffdes des virus (VPS): 0631-3, 04/08/2006
>Test du: 06/08/2006 16:50:22
>avast! - copyright (c) 2000-2006 ALWIL Software.
>http://www.avast.com
avast! Antivirus: message Sortant propre.
Test du: 06/08/2006 20:03:11
