Index last updated: 2026-04-29 00:01 UTC
Migration from 68LC302 to ???
2007-06-17 by Marty Burns
All,
Have a design using an 68LC302. We are starting a next version design.
Looking for a migration path to a more powerfull 32 bit processor. Looking
for small package (liked 100 pin TQFP) and the following:
1)       On chip FLASH >= 512KB
2)       Low power (<200ma, ~3V)
3)       2 UARTS
4)       1 Ethernet
5)       > 4 times speed of instruction execution as LC302
I am looking in the direction of an ARM9 series device. We will probably do
development using Windows box running Eclipse and cross compilation. Should
be able to debug using gdb over Ethernet or serial port.
Your thoughts are welcome.
Marty Burns,
Hypertek, Inc.
Re: Migration from 68LC302 to ???
2007-06-17 by Dimiter Popoff
Another choice I can think of - without flash and somewhat overkill,
perhaps - is Freescales MPC5200B.
 It consumes about 1W at full power - having a 400 MHz enhanced 603e
PPC core, with fullblown 64-bit FPU etc.
 You can connect two x16 DDR chips and have 64M or 128M etc. RAM;
you can (since the 5200 became "B") use even just one x16 DDR.
 I have seen a lot of Linux related offers through Freescale,
so chances are you will be able to run it (I am not a Linux user).
 I have put a free for development purposes debugger at
http://tgi-sci.com/tgi/download/m52.htm , you can use it to have
some start and perhaps later.
 I am planning to make a fullblown DPS available for the 5200B,
hopefully this year. How it will be licensed is TBD; it is a
separate world, does not stem from either Linux or anything else.
 It comes with VPA (Virtual Processor Assembler), which can
assemble CPU32 sources into PPC object code with minimal intervention
(that's how I migrated from 68340 to PPC, I had 10-15 megabytes
of sources for the CPU 32 and wanted to use them and move on;
the code size, unoptimized, is about 3.5 times the size for
CPU32 (resulting object code, that is).
Dimiter
Dimiter Popoff               Transgalactic Instruments
http://www.tgi-sci.com
> To: <68300@yahoogroups.com>
> From: "Marty Burns" <burnsmarty@...>
> Date: Sun, 17 Jun 2007 08:31:51 -0400
> Subject: [68300] Migration from 68LC302 to ???
> All,
> 3)       2 UARTS
> 4)       1 Ethernet
> Marty Burns,
> Hypertek, Inc.
Re: [68300] Migration from 68LC302 to ???
2007-06-18 by Aaron J. Grier
if you are executing from flash, you may not be able to get this, as
flash speeds seem to be limited to ~25MHz.  (the workaround is
copy/decompress to RAM, then execute...)
we are currently using 68331 and are moving to ARMs from Analog
Devices...
  Aaron J. Grier  |   Frye Electronics, Tigard, OR   |  aaron@...
RE: [68300] Migration from 68LC302 to ???
2007-06-20 by Fraser Hayden-ra9482
Please, take a look at our ColdFire processors. in particular the
MCF5282 and the Kirin family of devices. Both of these families have a
more powerful 32bit processor and Flash. There is a different mix of
peripherals between each. I can further help you if you have any
questions.
5282:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MCF528X&w
ebpageId=1113331549638725695448
Krin
http://www.freescale.com/webapp/sps/site/taxonomy.jsp?nodeId=0162468rH3Y
TLC00M95448
Hayden
                                          Hayden Fraser
Freescale Semiconductor                PHONE: 512- 895-2047/ FAX: x3585
32/16 bit C&I Operations
EMAIL:hayden.fraser@...
68K/ColdFire Applications                WEB:
<www.freescale.com/coldfire>
 [x]General Business Information
[ ]Motorola and Freescale Internal Use
[ ]Motorola and Freescale Confidential Proprietary
From: 68300@yahoogroups.com [mailto:68300@yahoogroups.com] On Behalf Of
Marty Burns
Sent: Sunday, June 17, 2007 7:32 AM
To: 68300@yahoogroups.com
All,
Looking
3) 2 UARTS
4) 1 Ethernet
do
Should
Marty Burns,
Hypertek, Inc.
