200e
Index last updated: 2026-04-28 22:38 UTC
291e
291e
2006-02-16 by JB
I just uploaded an mp3 (!) with a silly groove where the 291e is
driving three different
sounds. The 291e sequencer is going of course but no other sequencer
and there is
no effects on the sample. The 291e is indeed very versatile and fun.
A little programming trick for the 291e:
When adding the 291 to a patch it can be a drag if it's "zeroed" when
programming it,
going from stage to stage it will mute the sound. So to avoid this
make sure the morph
CV is unplugged, set the stages for control voltage and press play.
The sequencer will
keep the filter at stage 1 while you edit the other stages.
johan
