The Mellotron Group group photo
The Mellotron Group
Index last updated: 2026-04-28 23:38 UTC
Power consumption of an M400
2010-10-30 by nickhewitt25
Good Evening one and all
As a few of you know, I recently acquired an M400, serial number 360. One thing I've never seen is a technical manual for an M400, which, as an Electronic Engineer, would interest me a lot. I'd like to know the power consumption of an M400, as I need to know the size of fuse to stick in the mains plug. Also, does the M400 create power surges during normal operation, including the switch-on surge?
Nick, Edinburgh
Re: [newmellotrongroup] Power consumption of an M400
2010-10-30 by Rick Blechta
> Nick, Edinburgh
Nick,
You need to speak with the Official Mellotron Wankers of Streetly Electronics in lower downtown Uppppper Blithbury, Slightly North of Rugely Somewhere in the Midlands of the United Kingdom.
In other words, call Martin. He'll give you the correct gen and he might even answer your questions.
Trust me.
Rick
PS As an Electronic Engineer, believe me when I say that you don't want to know about all this. You have to take it on faith...
2010-10-31 by Elwood Dowd
Don't they burst into flames if you leave them plugged in?
To: newmellotrongroup@yahoogroups.com
Sent: Sun, October 31, 2010 12:38:29 PM
Subject: Re: [newmellotrongroup] Power consumption of an M400
>surge?
>Nick, Edinburgh
>Nick,
Trust me.
Rick
2010-10-31 by Bruce Daily
Hey Nick-
  If Martin diesn't respond first...
  5 amp standard fuses all around.  They should be rated 250 volts.  If one blows, get the unit troubleshot.  Good luck!
  Just a minute, gotta go unplug mine...
  -Bruce Daily
  #1221
Date: Saturday, October 30, 2010, 7:15 PM
Nick, Edinburgh
Nick,
Trust me.
Rick
Re: Power consumption of an M400
2010-10-31 by nickhewitt25
Thanks Bruce - I tried it today with a 5 amp fuse, and nothing popped, so I'm happy. At 240V, the motor is probably pulling about 500ma, and the pre-amp is 5/8 of damn all. What does concern me is the initial surge current when the motor speeds up to normal speed. I SHOULD know something about motors, but that was over 30 years ago - I learned it for the exam, then promptly forgot it! I'll try it tomorrow with a 3A and see what happens.
Nick from Edinburgh
M400 #360
--- In newmellotrongroup@yahoogroups.com, Bruce Daily <pocotron@...> wrote:
> Hey Nick-
> Â  If Martin diesn't respond first...
> Â
> Â
> Â  -Bruce Daily
2010-11-01 by john barrick
Bruce - that's in the power supply. The fuses on the motor controller card (at least the SMS4) are 1 and 2 amps.
john
On Sun, Oct 31, 2010 at 6:23 PM, Bruce Daily <pocotron@yahoo.com> wrote:
Hey Nick-
-Bruce Daily
#1221
Nick, Edinburgh
Nick,
In other words, call Martin. He9;ll give you the correct gen and he might even answer your questions.
Trust me.
Rick
Re: [newmellotrongroup] Re: Power consumption of an M400
2010-11-01 by Bruce Daily
Hey Nick-
   Yeah, the 3A fuse should tell you something.  Sounds like it may have the original CM motor controller on it, and they don't allow the motor to come up to speed very fast anyway.  The SMS controllers come up to speed nearly instantly.
   Here's some ways to help reduce the start-up surge.  Generally, reduce drag on all mechanical systems.  Make sure the capstan/flywheel and motor turn easily with the belt off.  Then, adjust the drive belt tension to allow about 1/2 inch of deflection, which is (from what I remember) normal.  A horizontally true motor helps, too.
   Good luck!
   -Bruce Daily
--- On Sun, 10/31/10, nickhewitt25 <no_reply@yahoogroups.com> wrote:
Subject: [newmellotrongroup] Re: Power consumption of an M400
Date: Sunday, October 31, 2010, 5:45 PM
Nick from Edinburgh
M400 #360
> Hey Nick-
> Â
> Â
> Â  -Bruce Daily
Good point, John!
  When I read "mains", I only thought about the power supply.  My SMS-3 controller is similar, it has 2A and 1A standard fuses, clearly labeled on the board.  My 2A fuse is a Slo-Blo, and I don't know if that's correct, but it's how it came.  The 1A is closest to the connector.
  -Bruce D.
Date: Sunday, October 31, 2010, 8:27 PM
john
Hey Nick-
  -Bruce Daily
  #1221
Nick, Edinburgh
Nick,
Trust me.
Rick
