Re: [motm] Non standard module uses
2000-07-30 by J. Larry Hendry
> From: Thomas Hudson <thudson@...> > Driving cross country jonesing for my MOTM got me thinking > about modules I wanted for specific functions, and then realizing > that existing modules could already do those things, though > not readily apparent. I know there are lot's or tricks I don't know > about and I hope I can spark a thread about this. I cannot think of a more intersting thread to get started right now. <big grin> > The one in particular for me was a comparator combo that would > output -5 V whenever an input voltage exceeded the set threshold. > I then realized that the 700 could handle the comparison function, > but I didn't have a source of -5 V. Then I realized that I could > take an 800, patch the plus out to the gate in, trigger it once and > get it to hang in sustain mode, then take the minus output for > my -5 V. I haven't tried this yet, since I'm still unpacking and > haven't found the box containing my patch cables :-(. You will be please to know that the 800 can be used as a voltage source without this trouble. Just plug NOTHING into gate or trigger. The sustain knob will give you control of the voltage output at both + and - polarity. Interestingly enough, if you set the attack and sustain levels up from zero they will lag the change on the output when you turn the knob to a predetermined change rate regardless of how fast you turn the knob. > I'm sure there are non-standard uses of a lot of MOTM modules > perhaps some of you share. Yes, let's here it gents. :) Larry H
