Reversing Top Copper Layer
2009-04-22 by Mike
Hello,
I'm using ExpressPCB for laying out my boards.  The majority are single
sided, but every now and then have to make a double sided board.  The bottom
side prints out okay for transfer to the board.  Unfortunately, the only way
I've been able to figure out how to get the top side oriented to transfer to
the board is to first make a transparency, flip the transparency over and
copy it to toner transfer paper.
Is there a way to print out the top side toner transfer ready to put on the
board using ExpressPCB?  Maybe another program that will flip the ExpressPCB
top side file?
  73,
  Mike, K4GMH
Re: [Homebrew_PCBs] Reversing Top Copper Layer
2009-04-22 by kabowers@NorthState.net
On Tue, 21 Apr 2009 22:55:37 -0400, you wrote:
>Hello,
>top side file?
I ran into the similar challanges with Free PCB and ViewMate on a
Laserjet 1022.
Get yourself a copy of Cute PDF Writer. It's free for noncommercial
use; the whole Cute PDF isn't. There's a free download about 1/4 of
the way down the WEB page.
href="http://www.cutepdf.com"
It loads as a virtual printer and outputs to a PDF file. When you are
ready to print the top, select "Cute PDF Writer" as your printer, go
to Properties,
select Advanced on the Layout tab, under Document Options->PostScript
Options select PostScript Output Option:Optimize for Portability
 and Mirrored Output: Yes
Under Printer Features->Print Quality Mode: Best
Now print the resulting PDF file with your usual printer set to 100%.
2009-04-23 by Mike
Hello,
That worked!  Thanks for great information.
> >Hello,
> bottom
> way
> to
> the
> ExpressPCB
> >top side file?
> Laserjet 1022.
> to Properties,
  73,
  Mike, K4GMH
