Re: [Digital BW] Comparing prints for that "3 dimensional quality"?
2006-11-24 by Diane Fields
I just wish I had been able to see the prints noted in several of these posts--yours and several others (I've looked at the online images that have been linked). I understand totally about the photographer and his input being the most crucial, but after saying that---I keep wondering about OEM (I'm waiting for a 3800, have a 2200 and 1280) vs., for instance, the Piezography's K7 split tone set for the 2200 or Paul Roark's UT-7 or Clayton Jones' approach using ABW with K3 inks. Think I will just continue to follow along, try the 3800 'as is' and then consider what more I"ll do. I have said previously, that I've procrastinated for years about using a b/w dedicated printer (conversion of my 1280) and working with QTR for monos in the 2200, so its not that I have to rush to make a decision, but the threads concerning the prints in NY/workflows, inks and printers by many and the results (though I missed the initial information about that and need to go back and do a search for the criteria) have gotten me to thinking about how I'm going to continue printing monos in the future. Diane ----------- Diane B. Fields picnic@... photo site http://www.pbase.com/picnic
----- Original Message ----- <snip> >>But I next had to check off another item on the list: inks. I dug around until I found a copy of the same image printed on an Epson k3 printer, with OEM inks, and (again) a PrintFIX PRO2.0 profile. So the main difference here was instead of a number of tinted gray inks interacting to form the tones here, it was predominantly one light gray for highlights and one dark gray for shadows, with supporting roles for the color inks as toners. I rather expected that the relatively fragile illusion of 3d would be clearly present in the monochrome inks image, and missing in the OEM inks image; but, to my suprise both images held the illusion in the same areas (subject, and backlit stemware to one side) and did not hold it in the same areas (back wall and knife rack). So, at least in this case, the "thinness" of OEM neutral printing did not effect the 3d illusion, or show (to my eye, at 24 inch examination distance) any real difference in detail, smoothness, or color noise. Gosh, you guys almost had me convinced. <G>
