Digital BW, The Print
UT-3D ink configuration for R220, R1800 and R2400
2006-11-23 by Jamie Creed
Hello all,
I'am just about to have a go with the UT-3D inkset with a few
printers and just wanted to check I've got the basic grasp of things
before I start.
Initially I'll try them in the R220 and was wondering if my choice
of ink is correct:
Eboni
C
LC
M
LM
Y
then when I go to the R1800 and R2400 I will use the LK and the LLK
inks also.
I haven't seen much conversation regarding the R1800, is it a wise
choice for a printer or is it likely to be problematic; I can see
plenty of info on the R2400 but I'd prefer to leave that for colour
work at the moment if the R1800 is up to the job.
Any opinions on my choices would be greatly appreciated,
Jamie Creed
Re: UT-3D ink configuration for R220, R1800 and R2400
2006-11-23 by horstenj
Hi Jamie,
I guess depends how you are going to drive them, via the Epson
driver or with a RIP?
I use UT3D on the 2100 (7 inks) with QTR. I have the same ink setup
as you decribe plus the UT3D LK toner. However, that LK toner is
actually idle since QTR (or another RIP) doesn't use/need it. It's
only there to make the ink set compliant with the Epson driver.
Joost
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jamie Creed"
<icucjamie@...> wrote:
> Hello all,
things
> before I start.
> of ink is correct:
> Eboni
> C
> LC
> M
> LM
> Y
LLK
> inks also.
colour
> Jamie Creed
RE: [Digital BW] UT-3D ink configuration for R220, R1800 and R2400
2006-11-23 by Paul Roark
Jamie,
>with a few printers and just wanted to check I've got
>the basic grasp of things before I start.
Be sure to check out my write-up at
http://home1.gte.net/res09aij/UT-3D_Readme.pdf
>... when I go to the R1800 and R2400 I will use the
> LK and the LLK inks also.
I have not set up an 1800.  It is such a different printer that I doubt the
UT-3D will work in its current configuration.
>I haven't seen much conversation regarding the R1800, ...
There are some people on the forum using it, but not with the 3D inkset.
Good luck with your B&W.
Paul
www.PaulRoark.com
Hi Joost,
thanks for the reply, guess I should have given a bit more info; I
intend to be using QTR and an X-Rite Pulse Spectro.
I'm curious about your mention of the LK ink being idle when using
QTR (have you produced your own curves for UT-3D with QTR?)
Jamie
> Hi Jamie,
setup
> Joost
> > Hello all,
> things
> > before I start.
choice
> > of ink is correct:
> > Eboni
> > C
> > LC
> > M
> > LM
> > Y
> LLK
> > inks also.
wise
see
> colour
> > Jamie Creed
Re: [Digital BW] UT-3D ink configuration for R220, R1800 and R2400
Paul,
thank you so much for sharing your work, I've been following your
expertise for severeal years now over here in the UK, and it's your
write-up on UT-3D that's got me all fired up again.
What ink configurations are people using with the R1800 - perhaps
UT7 or a custom mix? (by the way, I'm quite happy using QTR and an X-
Rite Spectro,) I take it that with the R2400, UT-3D works OK?
cheers Paul,
Jamie.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@...> wrote:
> Jamie,
doubt the
inkset.
> Paul
> www.PaulRoark.com
Jamie,
> ... your write-up on UT-3D that's got me all fired up again.
I'd become discouraged about the UT-3D inkset with all the production and
profiling disappointments.  But, now it looks like it might finally realize
the potential I was aiming at.  The MIS production batch I received a couple
of weeks ago was good, and now with ColorVision's software apparently able
to profile the inkset, it's really got me excited about it again also.  The
thought of a dedicated B&W inkset that can be manipulated like a color
inkset might be very interesting indeed.  I'll be testing the latest
PrintFIXPro software with it as soon as I can.  (It's downloading as I write
this.)
> perhaps UT7 or a custom mix?
The 1800 is different than the printers I've worked on.  So, it really needs
a different approach to optimize it.  I think Cone has a monotone for it,
but, as is obvious, I'm not a fan of inflexible inksets.  Right now I have
not recommendation for it.
Yes, although it'll be interesting to see how the K3 with Y=EZW compares to
the 3D in terms of quality and flexibility.  I had originally thought of the
3D inkset as for 6 and 7 ink printers.  The 2400 was just sort of tacked on.
It works fine with it, but it remains to be seen whether that is the optimum
B&W use of that machine.
Paul
www.PaulRoark.com
2006-11-29 by Jamie Creed
Paul,
I've had a slight rethink with regards to my choice of inks for the
R220 that I hope to be setting up this weekend with UT-3D, i'd
really appreciate your opinion on my choice of inks:
C
LC
M
LM
Y
LK
I was thinking that maybe the use of the dual gray approach with the
Toners might give me sufficient dmax, the LK would help with my
highlight smoothness and the Y will let me play around with the Lab
a* axis.
Jamie.
> Jamie,
production and profiling disappointments.  But, now it looks like it
might finally realize the potential I was aiming at.  The MIS
production batch I received a couple of weeks ago was good, and now
with ColorVision's software apparently able to profile the inkset,
it's really got me excited about it again also.  The thought of a
dedicated B&W inkset that can be manipulated like a color inkset
I write this.)
really needs a different approach to optimize it.  I think Cone has
a monotone for it, but, as is obvious, I'm not a fan of inflexible
inksets.  Right now I have not recommendation for it.
compares to the 3D in terms of quality and flexibility.  I had
originally thought of the 3D inkset as for 6 and 7 ink printers.
The 2400 was just sort of tacked on. It works fine with it, but it
remains to be seen whether that is the optimum B&W use of that
machine.
> Paul
> www.PaulRoark.com
