Digital BW, The Print
New Costco paper-any info?
2006-11-09 by Steven Karafyllakis
I found myself staring at the boxes of Costco paper a couple days
ago...they still had a couple boxes of the old stuff which I use for
color proofing, but being faced with profiling a new R260 I went with
the new paper so I wouldn't have to do it again when i did switch, and
have been pleasantly surprised. It was easier to get good color out of,
prints well with pigs, and has a nicer surface than the old paper. With
MIS inks it has a LOT of gloss differential, it needs coating. I'm
getting a dmax of 2.28 uncoated, 2.38 with Premier, and 2.58 with MIS
glop. Even though Premier doesn't give the most dmax boost, the surface
gloss and texture with it is quite pleasing, and very 'ADFB' in
character. I'll start a south-window test tomorrow, but in the
meantime, does anyone know anything more about this stuff?
Steve Karafyllakis
Re: [Digital BW] New Costco paper-any info?
2006-11-09 by Tom Baker
Which MIS ink are you using?  I don't see the gloss differential with the MIS PRO inks in the R220.
  Tom Baker
Steve Karafyllakis
Tom;
I'm using the K4 inks in the R1800 (no glop) and there's a lot of
it. A light coat of almost anything does the trick though.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker
>   Tom Baker
couple days
for
with
and
out of,
With
MIS
surface
> Steve Karafyllakis
Re: New Costco paper-any info?
2006-11-23 by Michael Hung
Any update on the new Costco paper? I went to my local Costco today
(London Ontario) and they still have tons of old stuff in stock and I
got two boxes..
- M
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
2006-11-24 by Steven Karafyllakis
Sorry Mike, can't add anything yet, the test strip hasn't been up
long enough to be meaningful. I should have a better idea by the
time you're done with the first box. I do know I like it better than
the old stuff, it takes dyes well and was very easy to profile.
Georgeous dye print quality.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael Hung"
and I
> got two boxes..
> - M
Epson R260 (was Re: [Digital BW] New Costco paper-any info?)
2006-11-27 by Sam McCandless
I don't know anything about the paper Steve is curious about, but I
am eager to know Steve's and others' impressions of Epson's new
printers and their new "Claria" inks, partly because they sound good
for business cards, envelopes, postcards and notecards, especially,
at least for me, if they print black-only.
Thanks.
Sam
> of,
> With
> surface
> Steve Karafyllakis
[snip]
2006-11-27 by Steven Karafyllakis
Hi Sam;
I haven't even tried the 'Grayscale' option on the 260-that's right,
it reads 'grayscale' which doesn't sound promising. For color, on the
new Costco, I'm getting excellent results after profiling: nice clean
colors that are life-like without being oversaturated. HOWEVER: Epson
has really done it this time: It's a whole new cartridge, and the
chip has two extra contacts, so you're stuck with Epson inks for a
while. Scuttlebut is, there's a pair of wires going into the cart,
maybe a crude sensor of some sort. Newegg.com has the best prices on
ink so far. My advice is, if you're looking for cheap mass quantity
printing, pick up a refurbed 220 or 340 while you still can.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Sam McCandless
I
good
especially,
> Thanks.
> Sam
for
with
switch, and
out
> > of,
paper.
> > With
MIS
> > surface
> > Steve Karafyllakis
> [snip]
Re: Epson R260 (was Re: [Digital BW] New Costco paper-any info?)
On Nov 26, 2006, at 9:36 PM, Steven Karafyllakis wrote:
> [snip]
That's right, and too bad, but not necessarily a deal-breaker for me.
> For color, on the
And this is promising - for color. But I care about that too.
> HOWEVER: Epson
All of my printing is done in small quantities. But I'm still
sensitive to the costs. And a little frustrated because I think ink
costs are getting more complicated to calculate. At a glance, the
NewEgg prices, neglecting taxes, shipping, and any rebate on returned
empties, look to me little if any lower _if_ the NewEgg prices for
the standard cartridges are compared to the Epson Store prices for
the larger "High-Capacity" Claria cartridges, which I _think_ only
the Epson Store so far has.
The number-of-pages cartridge yields, based on the new standards
still emerging for yields, are 300 vs 480 in the case of black and
515 vs 855 in the case of an all-colors average. I don't remember
seeing such new-standard yields for the 200 (I have) or the 220 and
340 printers. But I don't think the comparison matters much for those
of us who are proofing on them or using them for black-only printing.
> Steve Karafyllakis
> <samcc@...> wrote:
> [snip]
I hope Steve and others will keep the paper news coming. I'm
interested mostly in matte papers, and of the papers Epson is
recommending most highly for their new Claria inks, to me only the
Premium Semigloss and the Ultra Premium Glossy look promising for my
card-stock uses in terms of their specified weight and thickness. And
even in their case, I'm concerned about what it's like to print or
write on the uncoated, reverse side of the sheet - with any ink set
since I could change printers between sides, not that I was looking
for another complication!
Thanks again.
Sam
Sam:
I've been using MIS dye inks for years for my proofing and promo
work, and that makes the previous printers MUCH cheaper to run
, to me only the
my
And
set
looking
> Thanks again.
Sam:
 --I've printed some cards on the Costco, with K4 PK as it seems to
stay on better. Even then, They take hours to dry enough to handle,
and the slightest moisture smears the text. And both of the above
Epson papers are far worse: they not only have a very thick
polyethylene coating, they also have the Epson logo on the back.
I would suggest you try LexJet's Sunset Photo eSatin 300g for card
stock. Its as stiff as the Ultra Premium Glossy, prints qite nicely,
and while not as archival, it will certainly hold up long enough for
promo use and greeting cards. And the back is more paper-like, and
takes inks (PK at any rate) quite well.
And the front also does a good job with pigs, for B&W printing.
How all this squares with your desire to get the most out of the new
Claria inks you'll have to judge.
Steve Karafyllakis
2006-11-27 by wkm@kauaiphotos.biz
I too would like to know. I'd love to get some in 13x19 inch and roll sizes. I really like the paper and especially like the price. I've looked at the costco web site and they only seem to carry letter size.
Walt
>> of,
>> With
>> surface
>> Steve Karafyllakis
>[snip]
>Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
>- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
>- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See ?Group Topic, Rules and Guidelines? in the Files section:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ?OWNER? AND ?MODERATORS? OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  ?OWNER? AND ?MODERATORS? OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
>Yahoo! Groups Links
2006-11-27 by l33ry
If you don't mind me shouting from the novice gallery, Sam, I think
you're cheating yourself if you're not taking Epson's Epson-only paper
recommendations with a large grain of salt. All of those papers
predate Claria by a long shot, so their "optimized for Claria" claim
is pure hooey. Not only are there other papers out there with the same
characteristics, and better, many papers are available coated for dye
printing on both sides, from Hahnehmuhle, Bergger, Inkpress, etc. (and
also btw Epson's own double-sided matte @9.7mil).
To get an idea of what's available, try www.bhphotovideo.com, click
"Printers and Scanners" on the home page, choose "standard" or "fine
art" papers, and then filter for double-sided. B&H also stocks sample
packs from several brands.
For cardstock, I've only compared the Inkpress Matte 80 (12mil) with
Epson Matte Heavyweight (9mil and "optimized for use with Claria
ink"). The Inkpress was cheaper, seemed to me better on brightness
(actually brighter than I wanted), smoothness and yellowing, but it
flaked more than the Epson matte. Inkpress claims acid- and
lignin-free. I saw no difference in output on the 220 w/ OEM color
inks--very fine resolution, same colors.
I also tried Inkpress' Semigloss d-s and didn't care for it, but
that's probably a matter of taste.
Cheers,
Bob L
> Thanks again.
> Sam
2006-11-28 by Sam McCandless
On Nov 27, 2006, at 7:19 AM, Steven Karafyllakis wrote:
> [snip]
> Sam:
Thanks for saving me from trying those, Steve.
That sounds more like it, if not a strong case for adding an R260 to
my 200.
> Steve Karafyllakis
It looks like maybe it would be more of an experiment than I had in
mind, Steve, but I might do it anyway, and in any case, thanks again
for your help.
Sam
Not at all, Bob.
> I think
> is pure hooey.
Yes, but I thought the handful they singled out probably the best
they thought they had for the new Claria ink.
Maybe I should start with those instead.
Thanks for this tip.
> Cheers,
> Bob L
Thanks again, Bob, for this report.
Sam
> <samcc@...> wrote:
>> [snip]
Epson R260
2006-11-28 by Greg
A few people are saying that the Claria printers use ink much faster
than the previous R series printers. Something you might want to
consider checking out before making an investment. If the fade
resistance is real, then I can see the desire for these printers, but
if the ink consumption is really as bad as other people make it out to
be, I can't see these machines surviving very long.
Re: [Digital BW] Epson R260
[snip]
Me either, Greg, and thanks for this report, which I'll try to check
out, but I believe these printers are the first on which Epson has
reported on ink-cartridge yields based on a new and still "emerging"
standard. So I'm not optimistic about being able to compare yields
across the old-new standard divide. But if I can find paper I like on
which the Claria inks live up to Epson's promo, I'll probably be glad
to live with whatever the pages-per-cartridge yield is, especially
for envelopes, business cards, postcards, etc. Because I'd do those
in small quantities as well as small formats, and the R260 itself is
only about $100 (new, w/rebate), so it wouldn't be a big investment
for me.
Thanks again.
Sam
2006-11-28 by l33ry
Of course you're right, Sam. I agree that they are, ultimately, merely
steering customers to those of their papers that are best suited. But
Epson's language on their website implies more than that and I felt
compelled to voice my skepticism. Their claims that these ten-year-old
products are "optimized for use with Claria" and "designed for use
with the Ultra High-Def printers", products introduced this year,
strike me as a somewhat disingenuous and misleading way sell paper.
Many Epson papers are quite good, and for all I know they may indeed
be the best papers in the world for this ink, but I'd be shocked if
they were the only good options. Even from a marketing angle, I'm
puzzled by those statements, as they seem just as likely to backfire
as succeed.
But I am probably both ranting and digressing by now, so I'll shut up.
I wish you good luck and much fun in your quest, Sam.
Bob L
2006-11-29 by Sam McCandless
> as succeed.
I think you're right about all of that, Bob.
> Bob L
Thanks again, Bob, and please sound off if you think you see me going
astray.
Sam
