Check out this link for sharpening -
http://www.thelightsrightstudio.com/TLRSharpeningToolkit.htm
I always sharpen after resizing/resampling and at that point I use
two sharpening layers, one some type of high pass, and the other
some type of usm - both with edge masks (capture in the above
toolkit). Both types of sharpening have completely different
results so I like to compare the two and maybe mix them depending on
the image and especially the paper. The matte papers seem to be
able to take a bit more sharpening than the glossy papers (in their
various incarnations) without looking over done. I would print a
test that uses the same slice of an image with various sharpening
methods/amounts applied to see what works best with the paper you're
looking at.
I've got 2@250G so I think you're more than fine for a while!!
Brian
http://www.brianchapmanphotography.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "chriskjezp"
<chriskresser@...> wrote:
> Brian/Clayton,
> I also forgot to ask about sharpening. I read Clayton's workflow
for BO article, and unless
> I missed it I didn't see anything about sharpening. I've read a
few different things on the
> subject, and I know it depends upon the type of sharpening, but
I've always sharpened
> after resizing the photo to print dimensions.
> In terms of the color/greyscale question, I guess the best way to
find out is just to
> experiment. I like the idea of saving an RGB version which would
allow me to make very
> specific tweaks to the tone in ways that I'm comfortable with, and
then also saving the
> flattened greyscale version prepped for proof. I'm not too
worried about file space at the
> moment, since I'm an amateur fine art photographer (not prolific)
and I've got 2 500 GB
> drives to store the files on.
> Thanks again for all of your help - it is sincerely appreciated.
> Chris
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian
Chapman"
> <brianechapman@> wrote:
> > Chris,
> > As far as I know Clayton's main reason for converting to
grayscale
> > mode right after the conversion is disk usage, but I don't want
to
> > speak for him (just in case I'm wrong). As far as preparing the
> > file for printing, if there are any other disadvantages to
waiting
> > until the end of the workflow I haven't run in to them. You're
> > right though, keeping the image in RGB allows you to go back at
any
> > point in the process and tweak the conversion.
> > I think for the most part that you can duplicate most things
that
> > are done in the conversion process afterward using levels or
curves,
> > but there are times when modifying the relationship between the
> > color channels is the best way to go.
> > Brian
> > --- In
> > <chriskresser@> wrote:
> > > Thank you very much, Brian.
> > > I'm fairly experienced with B&W conversion methods in PS so I
am
> > relieved to know that I
> > > can continue working in that fashion and change to greyscale
just
> > before printing. I like to
> > > use Hue/Saturation and Selective Color layers just underneath
> > B&W conversion layer
> > > (gradient map, channel mixer or whatever) to gain more control
> > over the B&W tones.
> > > But is there any disadvantage to working this way? Clayton
Jones
> > recommends converting
> > > to greyscale directly after doing the B&W conversion of a
color
> > file and then doing levels,
> > > curves, etc. in greyscale mode. Doing it that way I'd lose
out on
> > all of the increased
> > > control I have over the B&W image using layers that are only
> > possible in RGB space.
> > > Best,
> > > Chris
> > Chapman"
> > > > Chris,
> > > > This tutorial is an excellent introduction to a couple of
> > most
> > > > popular methods used to convert an image to black and
white.
> > > > http://www.cambridgeincolour.com/tutorials/color-black-
white.htm
> > > > Any of these methods can be made more flexible by adding
> > > > additional 'conversion' layers (channel mixer, hue layer)
and
> > using
> > > > layer masks to allow only portions of each conversion layer
to
> > show
> > > > through. Different methods can also be combined. I am
> > currently
> > > > writing an article/tutorial describing ways to improve
> > flexibility
> > > > in some of the methods mentioned in the link (I'll post it
here
> > when
> > > > I'm done). Email me offline if you want the first draft or
have
> > any
> > > > questions, I'm happy to help.
> > > > In my workflow I choose to convert to grayscale mode just
before
> > > > printing because I like to work on the image as a black and
> > white
> > > > RGB image so I can make adjustments to the conversion as
well as
> > > > other tonal adjustments. Plus, if you're going to add a
toning
> > > > layer (maybe for the K3 with color toning) later you'll need
to
> > > > convert back to RGB to do so.
> > > > Anyway, I know this was slightly off the printing topic but
it's
> > an
> > > > important part of getting good results in print form!
> > > > Brian
> > > > --- In
> > > > > Clayton & Paul,
> > > > > Thank you so much for your thorough replies. I'm really
much
> > > > closer to understanding
> > > > > how this works, thanks to your generous help.
> > > > > It sounds like starting with an r220 and a variable tone
MIS
> > ink
> > > > set, along with Paul's ICC
> > > > > profiles and toning curves, is a good way to get my feet
wet
> > and
> > > > learn the ropes. And it
> > > > > sounds like this method can produce very good prints.
> > > > > Quick question: I'm assuming I can also use these ICC
profiles
> > to
> > > > do a soft-proof of the
> > > > > print in Photoshop. Is this correct?
> > > > > I guess I'll continue to use my Canon MP800 for heavily
> > > > toned/colorized B&W prints until I
> > > > > can afford a 2400. At that point I'll have more flexible
> > option,
> > > > where I can use RGB/color
> > > > > workflow when printing colorized B&Ws and the
ABW/greyscale
> > (or
> > > > QTR RIP) mode when
> > > > > I'm printing "classic" and warm/cool toned B&Ws.
> > > > > Thanks again,
> > > > > Chris
> > > > > --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton
> > > > Jones" <cj@> wrote:
> > > > > > Hello Chris,
> > > > > > >I've read over most of your webiste Paul, and also all
of
> > the
> > > > > > >articles on Clayton's website.
> > > > > > >I'm not at all sure at what point in the B&W conversion
> > process
> > > > > > >(from my color RAW file) I should convert from RGB to
> > > > greyscale.
> > > > > > I just recently revised article #9 (the 2400 workflow)
> > > > > > http://www.cjcom.net/articles/digiprn9.htm
> > > > > > and added more detail to the section on converting to
BW.
> > > > Basically
> > > > > > the first thing is to apply whatever methods you want to
> > remove
> > > > the
> > > > > > color while in RGB, and then change to grayscale mode.
At
> > this
> > > > point
> > > > > > the image is ready for any levels, curves and other
typical
> > work
> > > > as a
> > > > > > BW image.
> > > > > > >Another question that may help me decide on a printer:
with
> > the
> > > > K3
> > > > > > >printers (2400 in particular) is it recommended to also
use
> > a
> > > > > > >greyscale workflow for B&W prints, or is it possible to
get
> > > > good
> > > > > > >prints using an RGB workflow and applying any toning in
RGB
> > > > color
> > > > > > >space...
> > > > > > I think it's possible to get good prints that way, but
they
> > of
> > > > course
> > > > > > will have a different look and feel. The ABW mode uses
> > > > primarily the
> > > > > > three blacks with colors added only as toners, so the
tones
> > are
> > > > > > limited to a warm/cool range. If you wanted, for
example, a
> > gold
> > > > > > colored tone, or any other hue outside of the grayscale
> > warm/cool
> > > > > > range, then the RGB/color controls approach would be
> > required.
> > > > When
> > > > > > making BW prints with ABW there is no advantage to
keeping
> > the
> > > > image
> > > > > > in RGB. All you have is images that are three times as
> > large.
> > > > When
> > > > > > you switch to grayscale the image becomes 1/3 it's
former
> > size.
> > > > > > >How about the 2200 in this regard (though it uses the
UC
> > inks
> > > > > > >rather than K3 and is thus not as "archival")?
> > > > > > Yes, exactly. The K3 is much better in that regard.
The
> > K3
> > > > printers
> > > > > > are a big step forward in technology over the 2200 (and
> > 1280,
> > > > 220 and
> > > > > > the rest) for several reasons: better longevity, less
> > bronzing
> > > > and
> > > > > > gloss differential on glossy papers, three blacks for
much
> > > > better BW
> > > > > > prints, and the driver has essentially what is a built
in
> > semi-
> > > > RIP
> > > > > > with it's ABW system. ABW uses primarily the three
blacks,
> > > > adding
> > > > > > color inks as toners to create the warm/cool tone you
> > specify
> > > > with the
> > > > > > controls. Using a 3rd party RIP with the 2400 (such as
QTR)
> > > > gives
> > > > > > even greater control over the inks (for example,
eliminating
> > the
> > > > > > Yellow from the toning mix).
> > > > > > Regards,
> > > > > > Clayton
> > > > > > Info on black and white digital printing at
> > > > > > http://www.cjcom.net/digiprnarts.htm
