UT7/Mac/7600 questions
2005-01-10 by sandersm@aol.com
Two questions: 1. Must you use curves to control the UT7 inkset in an Epson 7600, if you install PK ink and print only onto Epson PSM or PSG papers? (I know you need curves for printing onto gloss papers with MK installed.) Or can it be controlled with only the Epson driver sliders? 2. Can the UC PK be used with the rest of the UT7 inkset in a 7600? Will it cause problems with print quality? Thanks in advance for replies. Sanders McNew. [Non-text portions of this message have been removed]
