Digital BW, The Print
Vs: [Digital BW] At my wit's end with my 1280
2004-04-16 by Ukko Heikkinen
Hi Peter, don't give up yet.
The printer is OK.
This seems to be very important:
What could cause too much ink to sit on the base of the print head? If you run too many cleaning cycles in succession, an awful lot of ink is held in the sponge. It will run down into a special large sponge inside the printer eventually, but initially, the ink could be carried back onto the head. The general recommendation is never to run more than two or three cleaning cycles at any one time. Ink sitting on the head risks it drying there, or in really bad cases being thrown off onto the paper, the rollers, or the pizza wheels as the head moves across the page and stops quickly."
Courtesy of
http://www.mwords.co.uk/pages/printers/printersPreventProblems.htm
"... air into the printer system causing nozzles to temporarily fail. If this is done accidentally leave the printer for 24 hours so that the air can dissipate naturally."
Courtesy of
http://www.lyson.com/
(Surprise: this really happens!)
(Bolding by Yours Truly)
Ukko Heikkinen
To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Sent: Friday, April 16, 2004 9:26 AM
Subject: [Digital BW] At my wit's end with my 1280
I regret to report that I'm still having clog troubles with my 1280.
I've tried the Windex tricks via both the printhead's resting pad and
flushing through the head with a syringe.  I ran a color cartridge
through the printer, printing both color, B&W with color ink, and
black only.  That worked OK with the usual cast and metamerism
problems when using color ink for B&W.
I bought MIS cleaning fluid, soaked the pad, let it sit overnight.
Didn't help.  I put in MIS cleaning cartridges, printed several purge
patterns, left it sitting turned off for a day. Repeated the next
day.  Put fresh MIS Ultratone and Eboni carts back in.  Got a few
beautiful prints.
Two days later, I have clogs again.  In several of the color
positions.  Most of these clogs seem to move around from nozzle check
to nozzle check, but the "yellow" position clog that started this
whole saga is still there, as always.
I'm about ready to give up on this printer.  It seems to do OK with
Epson color inks, although a couple of the yellow nozzles never show
up in the nozzle checks.  With the MIS VM and Ultratone inks, clogs
keep happenning.  When it works, the results are exquisite.  But I
have wasted countless weekends and several cartridges of expensive
ink, to no avail.
My next question is this:  Is it worth it to get the 1280 fixed, or
should I just cut my losses and get another printer?  If the latter,
I'm open to advice on which printer to get.  I want to be able to do
good, smooth, consistent B&W printing.  I don't want to spend all my
time screwing around with clogs.  I love the results I get from UT
inks, but it's starting to seem like it's not worth all the trouble.
Thanks for any advice,
--Peter
Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
Please follow these basic guidelines:
- As threads develop, trim off excess portions of earlier messages to keep them short.
- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Yahoo! Groups Links
