Digital BW, The Print
Canson Rag Photographique
2013-11-20 by <roark.paul@...>
This paper is OBA free; yet it has an unusually low Lab B -- slightly negative according to my spectro. Apparently Canson claims to add some "natural minerals" to achieve this whiteness. Does anyone know what they are adding?
I profiled the paper for the 7800 and Eboni-6. It has a good dmax and prints on the warm side, with a maximum Lab B of about 5.
Paul
www.PaulRoark.com
Re: [Digital BW] Canson Rag Photographique
2013-11-20 by Ernst Dinkla
> they are adding?
> Paul
> www.PaulRoark.com
Yes, for a OBA free paper it is very close to neutral. I think in your
case the UV-cut spectrometer has been compensated too much by the
software expecting an OBA paper due to the Canson's high reflection just
above 420 NM. My UV enabled i1Pro + Share says b 1.9, Mark McCormick's
Spectroscan etc meters keep it on b 1.0. So in both cases slightly
warmer. All the other OBA free papers are warmer, one or two come close.
An alpha cellulose paper with almost alike paper white in reflection and
color is the Innova IFA 24 Decor Art 210 gsm and its dual sided version
IFA25. A little more texture though and by its weight less opaque.  Much
cheaper for proofs and posters. You will like it. IFA25 can also be
found disguised as Harman by HM Matt Fibre Duo and Hahnem\ufffdhle Photo Matt
Fibre Duo. My best guess is that the alpha cellulose fibre is of a very
white quality where the Canson Rags (BFK that I use has it too) depends
on a very white quality of the rag + high quality whitening agents. So
the IFA24 probably will yellow earlier.
Kaolin, barite are all natural minerals. TiO2 less due to the
manufacturing process. With a scientific spectrometer it would be much
easier to check which whitening agents are use. Can't afford that.
Met vriendelijke groet, Ernst Dinkla
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
December 2012: 500+ inkjet media paper white spectral plots.
RE: Canson Rag Photographique
2013-11-20 by <phlg@...>
What minimum LAB L value do you reach?
Pascal
Paul
www.PaulRoark.com
Re: [Digital BW] RE: Canson Rag Photographique
2013-11-20 by Paul Roark
With Eboni MK in the 7800, the same-day QTR min. Lab L was 15.69. That's a dmax of 1.69. A few papers can do better, but I doubt anyone can see the difference.
Paul
Pascal
Paul
www.PaulRoark.com
