Digital BW, The Print
Epson 1430 Cleaning Solution
2013-04-30 by remononaz1
Last night I had quite a battle with my new Epson 1430, which I am using for color printing. The old 1400 is now a dedicated B&W machine.
It seems the black ink head was quite clogged and I emptied a full set of cartridges (MIS, not Epson!) doing head cleanings before I finally got a good nozzle check.
This got me thinking that I really should get some head cleaning fluid, but which one to buy? Most of the commercially available fluids are nearly as expensive as ink - and are probably just distilled water and a bit of ammonia and alcohol.
I have nearly a pint of PR-Clearbase-PT solution. Any thoughts as to how this would work as a head cleaning solution? Should I add a little ammonia and/or isopropyl alcohol?
RE: [Digital BW] Epson 1430 Cleaning Solution
2013-04-30 by Tom Maugham
I'm sure that everyone has his/her own favorite, mine is a 50/50 mix of
clear ammonia and water. I've used that quite successfully in a succession
of 1200, 1280, 1400 and now my 1430 either as an underhead soak or in
cartridges.
Note that these are all dye ink printers, I have no experience with
pigmented inks.
HTH,
Tom
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
remononaz1
Sent: Tuesday, April 30, 2013 10:21 AM
Subject: [Digital BW] Epson 1430 Cleaning Solution
good nozzle check.
Re: [Digital BW] Epson 1430 Cleaning Solution
2013-04-30 by Jim Coffee
When I place an order with MIS I always order a bottle of cleaning solution
also.  Simple.  And important.  Not that expensive.  Sure saves a lot
of hassle (and ink waste).
-Jim Coffee-
> good nozzle check.
2013-04-30 by Sylvain M.
Jus my 2c: A few months ago, I decided to keep my 1400 ON, and since
then I did not have clogging any more. Completely finished... Since I
have a CISS, I find this much better than cleaning!
Sylvain.
Le
> also. Simple. And
> of hassle (and ink
waste).
> -Jim Coffee-
>> ** Last night I had quite a battle
1400 is now a dedicated B&W machine. It seems the black ink head was
doing head cleanings before I finally got a good nozzle check. This got
ammonia and alcohol. I have nearly a pint of PR-Clearbase-PT solution.
> [Non-text
portions of this message have been removed]
------------------------------------ Please visit the Group Homepage to
check the Files, and other resources as they are often being updated.
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint [1] If you
wish to receive no emails or just a daily digest, or you wish to
unsubscribe, please edit your Membership preferences by visiting this
same page. Please follow these basic guidelines: - As threads develop,
trim off excess portions of earlier messages to keep them short. - Good
manners are required at all time. No personal attacks or flames.
Hostile, aggressive or argumentative users may be removed from the
membership without notice. - Keep your posts and threads related to the
group topic of digital B&W printing. Users who persistently make
off-topic posts may be removed from the membership. - By posting on this
forum you agree to abide by the group rules and guidelines, and to abide
by the actions and decisions of the group Owner and Moderators. See
?Group Topic, Rules and Guidelines? in the Files section:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ [2] BY
PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ?OWNER? AND
?MODERATORS? OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
?OWNER? AND ?MODERATORS? OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
unsubscribe from this group, send an email to:
Links:
[1]
[2]
[3]
[4]
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/join
[5]
mailto:DigitalBlackandWhiteThePrint-digest@yahoogroups.com
[6]
mailto:DigitalBlackandWhiteThePrint-fullfeatured@yahoogroups.com
[7]
mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
[8]
2013-04-30 by James Irelan
Anyone have an opinion on the Cone ColorPro pigment inks  vs the MIS K4 color inks in bulk, for a CIS in a 1430?  A concern is avoiding clogging.  Both tout their technology; MIS is almost 1/3 the price.
thanks,
James Irelan
2013-04-30 by William Harvey
Something like this happened to me with a 1400, turned out to be old
ink!! I put fresh ink in to the printer and everything was fine!!
Hope this helps
Cheers
> -Jim Coffee-
>> good nozzle check.
> Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
> If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
> - As threads develop, trim off excess portions of earlier messages to keep them short.
> - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
> - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
Default-WH
William Harvey
Mas de Cazes
Parisot 82160
France
Lat. = 44 degrees, 15.1 minutes North
Long. = 1 degrees, 50.6 minutes East
I looked at the ingredients in the PK-Clearbase and it sure looks like it would make a good cleaner. What's odd in this situation is that the 1430 is quite new. It was printing fine about four days ago and I have been leaving it on. I also leave my 1400 on and it rarely clogs, though it is running UT-14 which is pretty clog-free.
I don't normally have many clogging issues and this whole episode was a bit of an anomaly, but then the 1430 has been a mis-adventure anyway. If I had it to do over again, I'd pick up a used 1400, even if it didn't come with a new set of Claria cartridges.
2013-05-01 by Paul
Jim,
Although I have an R1800, I too order the MIS Cleaning Fluid whenever I order MIS Eboni. I'm using Paul's 3MK setup, with Eboni in the two black and GLOP positions and MIS Cleaning Fluid in the five color positions. Lately I've had bad nozzle checks in the Cleaning Fluid positions but not in the Eboni positions, which seems strange to me. In addition, I've tried using a 50-50 mixture of ammoniated Windex and isopropyl alcohol for underhead cleaning and soaking the waste pad. Sometimes this clears up the clogs but it's only temporary. (I should mention that I tint the cleaning fluid with a very small amount of Eboni so I can view the patterns.)
I'm beginning to suspect the use of this cleaning fluid in the carts... Paul has suggested I use his C6b mixture of distilled water, glycerin, Photo-Flo and LFN. I've mixed some up and am about to try that.
Any thoughts why the color position nozzle checks are problematic but not the Eboni ink carts? Any other suggestions on what to use in the color position carts?
TIA,
Paul
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jim Coffee <groups@...> wrote:
> -Jim Coffee-
> > good nozzle check.
